RC10 Worlds Resto
- slotcarrod
- Been thanked: 45 times
Re: RC10 Worlds Resto
What do you mean by worlds tub trim?
Rod Littau
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
It's a worlds tub car that had a really damaged chassis, so I put a worlds graphite chassis on it- the same car you see in this post, with a graphite chassis--what they should have done
- slotcarrod
More great info I did not know!Charlie don't surf wrote:Not just 10t hub carriers my friend, but 0 deg hub carriers. As I understand and have seen it it goes like this-RC10resto wrote:White 10T rear hub carriers
Worlds car released like this, then same as this but with different box and manual and the older stlye rear hubcarriers but this time the carriers are black and black spur, all black plastic and box with Kinwald/Drescher a gold foil sticker on the box and for the first time the "b2 stlye" shock collars
and bottoms.
Do you have the box and manual? If so, pics pleeeease!
Rod Littau
- slotcarrod
Wasn't the chassis the only difference? If not please tell me what!Charlie don't surf wrote:It's a worlds tub car that had a really damaged chassis, so I put a worlds graphite chassis on it- the same car you see in this post, with a graphite chassis--what they should have done
Rod Littau
- RC10resto
- Has thanked: 1488 times
- Been thanked: 550 times
Hey Rod,Do you have the box and manual? If so, pics pleeeease!
I think he is describing the box you have pictures of in your thread. I have the "other" box.
Brian
No way, the "worlds graphite" is just a 10talk nickname because of the masami shape of the chassis--it's just a 6036 with the TQ23/73 tires and a solid spur, short hinge pin rear arms.slotcarrod wrote:Wasn't the chassis the only difference? If not please tell me what!Charlie don't surf wrote:It's a worlds tub car that had a really damaged chassis, so I put a worlds graphite chassis on it- the same car you see in this post, with a graphite chassis--what they should have done
"other" box, the manual is burried right now, but I can PM you pics another time
- slotcarrod
Can you send me pics please!RC10resto wrote:Hey Rod,Do you have the box and manual? If so, pics pleeeease!
Brian
Never mind I will use Reg's pic, it's a different box from mine! Look at the side and the missing gold sticker!
Is Reg's box late or early?
Rod Littau
- slotcarrod
I have seen two of them (used) from non collectors on eBay. I nearly bought one, unmolested, it even had the box, it was like the team car box! I wish I had won it now! It was not called a worlds car on the box! I think it was a very late graphite team car. I wonder if they came with all the worlds car parts? DAMN I wish I had won it!Charlie don't surf wrote:No way, the "worlds graphite" is just a 10talk nickname because of the masami shape of the chassis--it's just a 6036 with the TQ23/73 tires and a solid spur, short hinge pin rear arms.slotcarrod wrote:Wasn't the chassis the only difference? If not please tell me what!Charlie don't surf wrote:It's a worlds tub car that had a really damaged chassis, so I put a worlds graphite chassis on it- the same car you see in this post, with a graphite chassis--what they should have done
Rod Littau
That would be correct, it was just the last version of the 6036 graphite team car produced for about 2 months as I'm told--box was a late team car box. All white partsslotcarrod wrote:slotcarrod wrote:Charlie don't surf wrote:It's a worlds tub car that had a really damaged chassis, so I put a worlds graphite chassis on it- the same car you see in this post, with a graphite chassis--what they should have done
I had one of the "late" Graphite Team cars w/ the Masami style chassis. I believe I got it in late 1994. Came with the Black "carbon composite" front and rear arms, but all other parts were white, and the shock towers were fiberglass.
Best RC10 "kit" I ever put together for dirt oval racing.
- 4840 Views
Last post by Worldsman
- 2088 Views
Last post by XLR8
- 1781 Views
Last post by DV8ion
- 694 Views
Last post by Synergy
- 46 Replies
- 4921 Views
Last post by mikea96
- 1930 Views
- 794 Views
Last post by CamplinP
- 1208 Views
Last post by sixdub
