Tire question/options for 870c
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Re: Tire question/options for 870c
Never new what those 7060's were for, but now I do. Darn they look good.
This is all very interesting!
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
- Has thanked: 36 times
- Been thanked: 1318 times
a good chance.
i have a set of schumacher mini pins, had them for years and they're used up. but, other than the fronts being narrower than the rears, they're identical. the crps shouldn't be any different.
I'd like to see those
, if you can round em up LMK- if they work then I'm in a real bind, because I have an idea of taking a set of 8086's and trimming them to 2.0 to match the stubbie fronts that Al has,( not exactly period correct, but--Flat Stubbie fronts!
) but if the CRP's look like the same outside diameter as my Shuy rears.......then
here's my worn out schumacher cat mini pins......
the fronts that roger has, and the tires in the link i sent you, would look like these. low profile front and rear.
hey my yoke 870c has proline tires on itpro 30 front an rear red compound tires hook up in the loamy stuff i have pics posted here on this site
Slingin mud baby
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
The only 2.0" tyres that I'll use on the race track are these Losi step pins. They are nice and soft and grip very well on a hard dry track when compared to what else is/was available.
http://cgi.ebay.com/Losi-Rear-2-0-Tires-Step-Pin-Silver-2-/400144410856?pt=Radio_Control_Parts_Accessories
- Bimdapogs
Has the 870C been sorted? I just remembered the tires on my Procat. They look similar to the one on the first post, but the pins are scattered rather than in rows.
The tires on your Pro-Cat is exactly what I ended up with, I had the rears NIP and luckly found the fronts new here
- 571 Views
Last post by vintage AE
- 30 Replies
- 9749 Views
Last post by RC104ever
- 3733 Views
Last post by bully
- 535 Views
Last post by juicedcoupe
- 2573 Views
Last post by PBR Allstar
- 3403 Views
Last post by Snaab9-2
- 19 Replies
- 2625 Views
- 4202 Views
Last post by n20capri
