Blackfoot - Which Thorp Transmission?
CNA75
Re: Blackfoot - Which Thorp Transmission?
Post by CNA75 »
highwayracer wrote:I had the sliders on my blackfoot and I liked them better than the dog bones. And yes, they were a cust down version of the list sliders from the JRX series.
Moving forward, you can use the sliders from traxxas to replace those. The holes are slightly smaller...but that's a quick fix.
Regards,
highwayracer
Sorry to ask again, but can anyone provide a link to the traxxas sliders that are referenced above?
aconsola
Post by aconsola »
CNA75
Post by CNA75 »
Thanks! Looks like the second is a closer resemblance to the Thorp ones..
CNA75
Post by CNA75 »
CNA75 wrote:
rctenracer wrote:tried the frog axles. the dog bones that i have are not the same size. :(
I think I need thorp pin drive axles.
Can I suggest that you look in to trying these: http://cgi.ebay.co.uk/Tamiya-53908-FROG-WILD-ONE-Universal-CVD-Drive-Shafts_W0QQitemZ200350884757QQcmdZViewItemQQptZRadio_Control_Parts_Accessories?hash=item2ea5d7e395&_trksid=p4634.c0.m14.l1262
I have a set of these and they are the CVD hop-ups for the Frog. They are a drop-in solution so may well fit with your Truck. When I get back home tonight, I'll check whether they have the pins in the outer axles and let you know....
EDIT: sorry I should have pointed you in the direction of these ones made by CRP (which are the ones I actually have). The outer axles definitely have the pins so you can fit the Sees and they are a straight drop-in solution: http://cgi.ebay.com/AXLE-CONV-KIT-Tamiya-Blackfoot-Monster-Beetle-CRP-9130_W0QQitemZ230374244235QQcmdZViewItemQQptZRadio_Control_Parts_Accessories?hash=item35a35fff8b&_trksid=p3286.c0.m14
shodog
Been thanked: 91 times
Post by shodog »
CNA75 wrote: Can I suggest that you look in to trying these....
The issue is that the ball on the end of the thorp dog bone is larger than Tamiyas which means the drive cups are larger also. With no support from the ball, those CVAs will only be riding on the pin and will quickly wear out the slot on the thorp drive cup.
aconsola
Post by aconsola »
looks like the crp kit is just some re-re frog parts with old school crp rear hubs.
for $35 you would probably be better off just buying the frog parts labeled as such but without the crp hubs for only $16:
http://cgi.ebay.com/NEW-TAMIYA-FROG-Axles-Rear-SUBARU-BRAT-BLACKFOOT-TF5_W0QQitemZ310165319497QQcmdZViewItemQQptZRadio_Control_Parts_Accessories?hash=item48374b2f49&_trksid=p3286.c0.m14
CNA75
Post by CNA75 »
aconsola wrote:looks like the crp kit is just some re-re frog parts with old school crp rear hubs.
Good point. Although I don't think those outer axles have the pins for the Sees wheels.
Would the solution be to replace the drive cups as well as the dog bones? Guess that would mean getting rid of the Thorp cups though....
bearrickster
Post by bearrickster »
the frog CVD set does I just put them in my Frog and they have the drive pin for sure
LOSI RULES!!
Bearrickster's Rides
vwjuice
Post by vwjuice »
I have a set of sees wheels and they use the standard tamiya style cups. Do the newer axles have pins to hold the stock cups on like the older ones? I would think you could just pull the stock cups off and slide the wheels on.
bearrickster
[email protected] wrote:I have a set of sees wheels and they use the standard tamiya style cups. Do the newer axles have pins to hold the stock cups on like the older ones? I would think you could just pull the stock cups off and slide the wheels on.
thats what I had to do on my midnight pumpkin. the CVD's have the pin and take the stock plastic hub.
LOSI RULES!!
vwjuice
Post by vwjuice »
Whoa I was right? Gotta mark this day on the calender. :lol:
shodog
Post by shodog »
The outdrives of the thorp have a hex mounting to the diff and are sized differently in length. There is now way to use the stock stuff with it.
highwayracer
Been thanked: 6 times
Post by highwayracer »
The ones that will work with the blackfoot are from the 4tec.
Return to “Tamiya Forum”
