So, what did you do RC today?
TravelinTravis
Has thanked: 987 times
Been thanked: 372 times
Post by TravelinTravis »
Replaced two corroded 9 volt pigtails on a Lavco Cell Mate 20 and added deans and XT90 connectors to another Novak Digi-Peak Plus charger.
Has thanked: 2604 times
Been thanked: 2977 times
I have this motor that doesn't run.
I think I know why now. It's not just the comm that looks like it met an arc welder. It's not the brushes, because it doesn't have 2 anymore. The one that's still there isn't the issue. :wink:
Definitely not the sort of brush and spring setup that I'm used to.
RogueIV
Has thanked: 2135 times
Been thanked: 1099 times
Post by RogueIV »
"fixed" the world's worst running JRX (that somehow isn't winning POS of the month) hopefully this time at least 1 camera will work.
Been thanked: 3917 times
Well it was more my wife but we finally got around to doing some sublimation prints and they turned out ok! Pretty amazing technology. This really opens up some possibilities 😅
Shirt art done by Joe Neri of braindead designs
MarkyDents
Has thanked: 1809 times
Been thanked: 643 times
Post by MarkyDents »
Sweet FW/A&L swag Jeff 8)
Hey Cru ! Go balls out 8)
Has thanked: 268 times
Been thanked: 2094 times
Finally got around to trimming and mounting the body on my Sorta Mud Blaster project.
mikea96
Has thanked: 659 times
Been thanked: 878 times
Post by mikea96 »
Helped my son with his b6.3d with fresh body and wing and new jconcepts wheels and smoothie slicks.
RogueIV
Post by RogueIV »
Did a little work on the Cougar 2 Works. shimmed the top shaft of the trans after getting annoyed at a rubbing sound. Added a Factory Works bulkhead brace. Put on some JC Racing aluminum yok wheel adapters and slapped some YZ-10 wheels I had on it. Unfortunately the fronts required a shim to be able to properly tighten the screw down without clamping the adapter to the hub. Realized I forgot to add the wheel stiffeners when I ordered from Factory works so kinda made some out of some spacers I had. It looks interesting.
1911Colt
Has thanked: 1782 times
Been thanked: 859 times
Post by 1911Colt »
RogueIV wrote: Tue Mar 18, 2025 12:34 am Did a little work on the Cougar 2 Works. shimmed the top shaft of the trans after getting annoyed at a rubbing sound. Added a Factory Works bulkhead brace. Put on some JC Racing aluminum yok wheel adapters and slapped some YZ-10 wheels I had on it. Unfortunately the fronts required a shim to be able to properly tighten the screw down without clamping the adapter to the hub. Realized I forgot to add the wheel stiffeners when I ordered from Factory works so kinda made some out of some spacers I had. It looks interesting.
Factory Works bulkhead brace? I must investigate... :D
I notice you have the battery hold-down screws towards the front of the chassis like on the Top Cat and Cougar. I did the same but I found that the body will not seat properly that way on the C2W. The inside ridges of the body contact the thumbscrews. The body rides a few mm high (and it will eventually damage the paint). I flipped the posts around so that the thumbscrews are in the back of the chassis and it solved the issue.
Maybe the manufacturing tolerances just stacked up against me and yours will be ok. I would test fit it, though, or at least put some tape on the inside of the body to protect the paint in that area. I read a few complaints online that the body line was in the wrong place and that the body was effectively too short, but I think this is the real problem. I cut right on the body line and mine sits perfectly with the posts flipped around.
RogueIV
Post by RogueIV »
1911Colt wrote: Tue Mar 18, 2025 8:21 am
Thanks for the heads up, i'll flip that around, although i may have to cut the posts down to fit my lcg lipos without having to space them.
HS-YZ250
Has thanked: 178 times
Been thanked: 155 times
Post by HS-YZ250 »
Got a little more done on my Super Rocky body. Hoping the paint scheme I chose isn't too over the top.
Losi LXT (JRX-T Conversion)
Losi JRX Pro SE
Kyosho Rocky
Parts-Car-to-Runner Kyosho Rocky
Yokomo YZ10 WCS '95 Pavidis
RJ Speed Spec10 "Chew Toy Mk1"
Redcat Lightning STK "Chew Toy Mk 2"
Kyosho Lazer ZX, ZX-R, ZX-RR
TravelinTravis
Tearing down six new 2500mah SCR NiCd stick packs to saddle packs.....new Old School labels and shrink wrap along the way.....next, warm up the soldering iron.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
Nice, that's a fun job....
Time to break out the cell matcher and make some matched cells :lol:
pma1123
Has thanked: 503 times
Been thanked: 107 times
Post by pma1123 »
Getting the C2W closer to running...photo to accompany the story.
I've been weaving a tapestry of RC profanity over here.
Don't ask me what I think of my R1 Wurks ESC.
And now the story...I had this R1 ESC installed, bench testing stuff a few times, working great, cool, neat, wow....
At the time I was marveling over the WiFi connection/adjustment of this mystical black box.
Decided on Saturday night I couldn't leave well enough alone and updated the firmware to match the latest 1.8 version.
Got most of the way through that (file 47 of 49) when my phone received a Costco push-notification text, failed upload message appears.
And now the ESC won't light up when switched on...BEC works great.
The ESC got BRICKED!!!! :evil: :evil: :evil: NFG!!!!
Since this R1 ESC was working fine with the old firmware; I am owning this as a self created unnecessary expense.
The car is rocking a Tekin ESC now. Vote with your wallet... :P
Test run will be 13.5T, 87T Kimbrough spur and 29T pinion.
RogueIV
Post by RogueIV »
JRX ProSE got it's steering repaired, RPM 0deg toe rear block installed (Thanks @Charlie don't surf ), and fixed a JC Racing rear wing to it. It's ready for this weekend's race!
I got the Cougar 2 Works in driveable state, granted I still need to paint the body. Really excited to see how this car performs.
