Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Awesome thanks. I thought the 12L only came with the aluminum motor plate but did another search just now and found a couple of pics of the nylon one. The mounted axle too seems to be from a 12e...it's hollow.
Been thanked: 3919 times
Yeah 12e could have been solid solid axle, solid hollow, or hollow diff. Lots of running changes! My lightweight 12e has a hollow steel diff axle.
That diff hub on the axle that's in the carriers is not 12e. Looks 12L to me, due to width
Phin
Post by Phin »
The 12L diff has a teflon(?) spacer inside it doesn't it? This one doesn't...it's all aluminum and too narrow for an insert. It's also meant to use a diff ring with a smaller ID than the standard Assoc ones.
I'm not sure, some diff hub hubs use a small stealth size ring but not sure which ones. The 12e and 12i use the same rings as a RC10
Maybe I am looking at it wrong. Is the hub on the axle more than one piece?
lpddpd
Post by lpddpd »
Could that axle be from T&A Machine? Had a hollow one from them for a 10LSS in the past.
Looked like this
Phin
Post by Phin »
I wish it were, but given the rust on it I'm gunna say it's not titanium. :wink:
When you get a chance post up a pic if the axle and if the hub comes off remove it so we can see what we are dealing with. As it sits I don't quite see what it is- if the hub comes off there should be a hub on the axle to hold a diff ring, if its part of the axle then it really makes no sense
Phin
Post by Phin »
Longer axle is the hollow one. Shorter one is solid. Both are tapered at around the 4" mark on the ruler, and that's what holds on the two thin, inner diff hubs in place. The ID on the thicker hubs is larger than the dia. of the axle. The two bronze hubs are a touch too large for an Assoc. diff ring,
The diff hub.
The hub looks familiar but I'm really out of touch with the newer stuff (lol)
I think you have a couple great 12i/e axles and hubs but the rest....I don't know
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Post by Hcp22 »
I got hold of this old speedo for the Kyosho Scorpion on the German eBay. Is there anyone how knows anything about this company MIH (Modell Import Hamburg)? Did they manufactory this speedo them self’s or did thy just repack it? If so, how made it? :?:
MIH 3.JPG (31.29 KiB) Viewed 1213 times
Cheers
Lars
My Feedback
I am guessing 1/10 pan car nerf (nurf?) Wings but for what car?
farmer
Post by farmer »
unknown diff
any idea's
thx farmer
Hcp22
Post by Hcp22 »
Isn’t MIP SP1 a gear diff and the one above a ball diff?
Cheers
Lars
My Feedback
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
What Kyosho Lazer is this? The front end is wide...
Return to “Identifications”
