You aren't wrong, but every penny I spend with Amazon is one kept from a local business.juicedcoupe wrote: ↑Sat Mar 01, 2025 6:01 amThey are cheap on Amazon.R6cowboy wrote: ↑Fri Feb 28, 2025 7:47 pmThis is one thing I have in my list next time I go to the LHS.Frankentruck wrote: ↑Fri Feb 28, 2025 6:04 pm I needed a 3mm tap and the hardware store didn't have one that small. So I went to my LHS. I ended up teaching the friendly but clueless young 'un what a threading tap was and showing him where they have them. But he was thankful for both lessons so it was worth overpaying for it there.![]()
You can probably buy a set for what the LHS wants for a single one.
So, what did you do RC today?
- Has thanked: 234 times
- Been thanked: 211 times
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Most of the taps at my desk are Irwin or Bosch. I also have a 8-32 Milwaukee impact tap for RC10 chassis and modifying 4mm flange nuts for RC10 axles.Frankentruck wrote: ↑Sat Mar 01, 2025 8:01 am I don't know how good or bad the quality is for the Dubro, but a Drill America tap was the same price on Amazon and they are usually ok quality. I wanted it yesterday, literally because this was yesterday, and I was throwing a couple $ at the LHS.
Some came from Amazon, others Lowes and Home Depot.
Don't misunderstand. I spend plenty of money at my (semi-local) LHS. Even though it is kinda out of my way, I've been shopping there for over 30 years.
And I'm more about equal opportunities. I waste my money with everybody.
But with me also being a full size car and boat guy, I probably have a little different perspective than the typical rc guy concerning tools.
If I step out to my shed, these are my other taps. I also have several randoms in my tool box, as well as NPT taps and dies.
@juicedcoupe
I hear you.
Also, I'm into old Toyotas, so a torch, a set of left hand drills, and metric Starrett tap/die set are also always near.
I hear you.
- MarkyDents
- Has thanked: 1809 times
- Been thanked: 643 times
I have that exact Craftsman set for more than half my life and it’s helped me out so many times it’s countless. Good to have around.juicedcoupe wrote: ↑Sat Mar 01, 2025 4:09 pmMost of the taps at my desk are Irwin or Bosch. I also have a 8-32 Milwaukee impact tap for RC10 chassis and modifying 4mm flange nuts for RC10 axles.Frankentruck wrote: ↑Sat Mar 01, 2025 8:01 am I don't know how good or bad the quality is for the Dubro, but a Drill America tap was the same price on Amazon and they are usually ok quality. I wanted it yesterday, literally because this was yesterday, and I was throwing a couple $ at the LHS.
Hey Cru ! Go balls out
- R6cowboy
- Has thanked: 871 times
- Been thanked: 903 times
Nothing picture worthy yet, but started working on RC10 B4 (Masami tribute) body work.
My brother passed along all his airbrush supplies to take over r/c body work because he's too busy working on my 1970 Mach 1.
-Jerry-
- Frankentruck
- Has thanked: 2604 times
- Been thanked: 2977 times
Finishing up a couple of pairs of fronts for an upcoming Ten 4.1 project. I still need to drill the axle and screw holes to size.
- Has thanked: 1129 times
- Been thanked: 3917 times
If you are going to use jconcepts tires you will want to make the ring wider. Not sure how their tires got so far off but it was frustrating to try to get them to mount on 3pc wheels
- Frankentruck
I have some Schumacher tires I was going to try. Which JConcepts tires are you thinking of?
I used their Step Spike on a build, as well as their matching rears
I should have made the post yesterday, but got home so late and forgot to today. Saturday I attended a race a couple hours away, watched a couple friends race. So this is an indoor track and it's dirt, but it's so hard packed that they run tire additive and use tire warmers. The tires are slicks. Never in my life (I know this is very common, but I haven't been to a track in years) have I seen such a "dirt" track. The cars come off the track spotless like they were on carpet.
Also they race oval, this week the oval was very small but the cars.. holy crud .. I've never seen so much crazy geometry they look broken. The rears have so much steering built into them. It's just insane.
RC has gotten weird
RC has gotten weird
- Frankentruck
The Schumacher spike rib tires are a good fit for the front wheel. That's probably what one of my Ten4.1 builds with use.
- Has thanked: 117 times
- Been thanked: 243 times
Cleared of the track after the winter finally seems to let up.
When that was done I raced my Blackfoot against my brothers Monster Beetle.
//Johan
Still sunny weather today. So this years runners had their first run.
My brothers Ultima II Evo, rere transmission and shocks, JC Racing front arms, 3D- printed Pro XL rear arms, Factory Works steering, Novak 410-M1c, LRP V10 14 double brushed.
My XX (CR converted), JC Racing front arms, Sabula Tech front bulkhead, Novak Racer esc, Peak 13 tripple brushed.
//Johan
- 5562 Views
Last post by Dr. Robotnik
- 20 Replies
- 10367 Views
Last post by cas22
- 6457 Views
Last post by Synergy
- 6690 Views
Last post by ireg
- 5712 Views
Last post by clm
- 2719 Views
Last post by mrlexan
- 2425 Views
Last post by DHood
- 2570 Views
Last post by Winger
Users browsing this forum: Semrush [Bot] and 2 guests
