I think I'm gonna have to start a "free" thread for a lot of this junk I'm getting that isn't worth selling but too good to toss
Gear set is for GH/Hornet, Lunchbox, etc that had the long, rigid hex axles. It seems to just be the diff/outdrives without the counter gear. If I recall bitd they sold them separately, as the counter was always the 1st to go.EvolutionRevolution wrote:Anyone know what these are?
Gear set for what? guess the metal motor mount is for an airplane, plastic motor mount Tamiya???, top deck for what?, unknown carbon bit, and the graphite piece may be Yokomo???
Had it ben 12t 1.0 module, then I had known… and wanted it badly…gomachv wrote:52t on the big end, 18t small. 8mm hole on one side, 11mm on the other. Should narrow it to tamiya or 100 other manufacturers![]()
If you can provide a pic of a car you own that could benefit from this gear I will send it to you. Yet Another part I don't need!
PK Corally chassiscyberfox wrote:Hi,
Can you please help me to indentify this chassis, it is for Optima Mid, but I don't know anything else about it![]()
Thank you.
DennisM wrote:Then we discovered the different versions of alloy.
gomachv wrote:DennisM wrote:Then we discovered the different versions of alloy.
