Optima is back!!
DennisM
Has thanked: 30 times
Been thanked: 62 times
Re: Optima is back!!
Post by DennisM »
They´ve done a great job on the driver - looks a bit more scale´ish.
Looking forward to cutting an Optima body with cutting lines :mrgreen:
Gone fishing
aip47-2008 wrote:
DennisM wrote:
yellowdatsun wrote:There's no pics of the axles *without* the aluminum hex on there. I do see a set screw, so I'm REALLY hoping these aren't those press fit pieces of garbage.
Why garbage?
I never had one come loose
If anything.........sometimes they were hard to get off. :lol:
Exactly...those hexes sometimes seemed like they were WELDED on! And yes, I've had some slip too.
Grunger73 wrote:
GoMachV wrote:I'm hearing a street price of 299
You are correct. That is the listed preorder price. Available March 31. I just preordered mine :D
It looks like the bumper is mounted differently. Hopefully no more bent or snapped front support.
I wonder what they're using for a battery? Finding a LiPo pack that fits in the original Optima's battery receptacle is now damn-near impossible. Years ago, I managed to find some Gens Ace 2S packs that were very close to the original 8.4V NiCad pack dimensions, but even those required some minor filing down of the plastic battery holders in order to fit. Modern 2S LiPos--shorty or otherwise--don't even come close to fitting without major modifications. Furthermore, 8.4V NiCads were too long to fit inside the Optima body...the Turbo Optima had a wider body to accept the longer packs.
Been thanked: 3919 times
They say it's lipo compatible so they must have changed the mounts.
GoMachV wrote:They say it's lipo compatible so they must have changed the mounts.
I'd love to know what LiPo battery with vintage stick-pack shape is short enough to fit inside the Optima body...I'll buy some immediately. :)
The length of a lipo vs a stick pack isn't much different....not sure why it would be a problem?
GoMachV wrote:The length of a lipo vs a stick pack isn't much different....not sure why it would be a problem?
A LiPo is about as long as the old 8.4V stick packs...which didn't fit the original Optima body. Even the now-impossible-to-find Gens Ace packs I bought that have similar dimensions to the old stick packs BARELY fit inside the Optima body.
http://www.hobbypartz.com/98p-25c-4000-2s1p-hardcase-direct.html
This is the only one I found that barely fits; but it has been out-of-stock for years now. It's a major challenge to find anything like this one now. Try finding a current 2S LiPo that's rounded on the edges and less than 140mm long...
BoostCreep
Post by BoostCreep »
Those should work...never even heard of that brand, though. Thanks for posting that. I've spent hours going through eBay and Googling trying to find decent 2S LiPos that were short enough, and other than the apparently discontinued ones, I found nothing.
BoostCreep
Coelacanth wrote: Those should work...never even heard of that brand, though. Thanks for posting that. I've spent hours going through eBay and Googling trying to find decent 2S LiPos that were short enough, and other than the apparently discontinued ones, I found nothing.
I bought some of the 4000mah variety and they've been working just fine so far. Price is right too.
DennisM
Post by DennisM »
My standard size 2 cell LiPo hardcase are 136 mm long which is about 6 mm longer than a standard NiCad battery.
They fit fine under the std. Optima body.
Gone fishing
DennisM wrote:My standard size 2 cell LiPo hardcase are 136 mm long which is about 6 mm longer than a standard NiCad battery.
Those won't fit the stock Optima battery receptacles though. Hardcase LiPos are square-edged, not rounded, so you either have to mod or remove the stock receptacles, which are curved. :P
yellowdatsun
Post by yellowdatsun »
Everything else that has been re-released, by any company, has been modified to accept Lipo packs. I don't see why the Optima would be any different. The Tomohawk and Scorpion both accept Lipos now.
I realize that. Go back to my first post on the matter and the picture showing what appears to be a standard stick-pack that's quite short...it's not a LiPo, from what I can tell. Other than the battery packs linked by BoostCreep, a curved pack that's 2S and short enough to fit is very hard to find.
DennisM
Post by DennisM »
The battery mounts on the re-re are flat, so it shouldn´t be a problem
http://reports.kyoshoeurope.com/en/legendary-series-optima-toutes-les-photos/
Gone fishing
Return to “Kyosho Forum”
