Discussion about possible aluminum transmission and parts
Been thanked: 1319 times
Re: Discussion about possible aluminum transmission and part
ya, too many dowels. i think the one on the bottom would actually be in the way of the mounting screws anyway. that's how it looks in that pic anyway. it might not be...
the associated trans gears should be run dry. they are self-lubricating. the only kind of grease that should be anywhere inside that trans is on the diff balls. so there shouldn't be anything that could run out. i don't see much chance of dirt getting inside with 2 mating machined surfaces either. but, i guess it could happen.
Johnboy72
Post by Johnboy72 »
This thing will be a tank. I appreciate everyone giving walt feedback because without it, walt would truly over engineer and over build it. Lol
SnoopMaxx
Post by SnoopMaxx »
Walt
I had a good look at the prototype case
And I think you have too many dowels :lol:
Lay the original nylon case half over the alloy, and you'll know what I'm talking about
The thin red is just a suggestion to make it look like the 6 gear case
Will the outside be flush like on the MIP and 6 gear case ?
I trimmed the inside of my case, ca 0.6mm wider and yes it was just to give it a little radius (thick red in your photo)
Morten
Morten Max
wyldbill
Post by wyldbill »
i vote for the tube idea that jwscab suggested, just one in each corner hole in stead of all 4. that sounds the easiest just oversise the holes slightly and install some brass tube. i really wish that Birdsboro was still racing on the concrete, i could have oval tested them for you. 1 in the truck and 1 in the edm would have been sweet.
SnoopMaxx
Post by SnoopMaxx »
Not a good idea Wyldbill
Look at the photos, 2 of the holes are too close to the main gear, in order to make that work you will have to relocate the holes and make a new motorplate .... It's only possible on the upper holes
The idea is to make a gear box that works with the standard chassis and motorplate
Morten
Morten Max
300D50
Post by 300D50 »
Thank's for the input everyone.
The hollow dowels would end up being a PITA to source and/or manufacture, I've been there with actual car transmission adapter plates...
I also have about 1000(no joke, the bag is huge) 1/16" diameter 5/16" long dowels, so it isn't a big problem to supply them and a few extras if needed. Price point would be unchanged since i'll never end up using them all to begin with.
The dowels were placed so as to not interfere with the screw holes, I just didn't machine further than was needed to get the geartrain tested.
The reason for so many dowels is a little less obvious.
First of all, I'll be making a few of these out of delrin, and those could use the added rigidity.
Secondly, they are being used to align the parts to a fixture during a second operation, and I'd rather have them super-rigid during that, and even more so with the delrin since it does like to flex a bit.
It's actually cheaper for me to prototype everything in Aluminum due to the price of the delrin and the fact that I can recycle the chips. Who'd think plastic is twice the cost of the same size aluminum stock...
Looks like we're getting a small radius on the edges, and in an odd twist it's cutting down the cycle time by a few seconds!
Walt
Some people never have anything except ideas. Go do it.
SnoopMaxx
Post by SnoopMaxx »
Two of the dowel will need to go mate, they are at the edge of the case
Any chance you could use the screw holes as fixtures when you mill the outer part ?
Morten
ahh wait you have to countersink the screw holes :roll:
Morten Max
Johnboy72
Post by Johnboy72 »
Question...what trans did you use Walt? Is this just an aluminum replacement or is this the 6 gearbox looking transmission using stealth gears inside?
300D50
Post by 300D50 »
Johnboy:
It's the replacement, but the model can easily be tweaked to work with either form factor.
I assume it's just the 3 gears going in a look-alike housing that allows it to bolt right up to existing cars?
Morten:
Which ones would have to go?
Everything is nicely within the envelope of the existing housing as far as my solid models are concerned, I just never milled the outer profile because I don't have the fixture completed. It might look worse than it is due to the angle of the photo and the fact that the dowel holes were spot drilled the same depth as the main screw holes were.
Walt
SnoopMaxx
Post by SnoopMaxx »
Walt
I removed 4 of the dowels that I think is not needed because the 4 screws also help strengthen the case but if they are inside the case halves .. :wink: It might just be the angle of the photo then,
here's a before and after .... lol
Just do your thing mate :D
I can't wait to see the outer case milled
Morten
Morten Max
300D50
Post by 300D50 »
The screw holes won't do much to help align the case, since they are over-sized to allow the screw to pass.
The trick that the nylon housings use of under-sizing the holes by a thousandth or so won't work that well in aluminum either.
They do however apply a clamping force to keep the halves together, which is needed.
The angle of the photo is a big factor, as well as that errant spot drill countersinks. They make the dowels look a lot bigger than they are.
Please don't think I'm trying to do the whole "I know more, so it's my way or the highway" ordeal, I'm just trying to explain my reasoning. I tend to make things so that they function well, last, and look good.
I'm also a slight perfectionist who's used to making precision parts, so it tends to carry over a bit...
Walt
SnoopMaxx
Post by SnoopMaxx »
:wink: That's just like me :mrgreen:
and I know what your talking about, regarding machining procedures :lol:
Morten
Morten Max
300D50
Post by 300D50 »
Another day in paradise...
click for larger
Comes in at a little under 17 grams a side, or roughly double the weight of the nylon version.
Walt
SnoopMaxx
Post by SnoopMaxx »
Oh my :shock:
I'm astounded by the detail, no wonder Jonny says you sometimes over engineer parts :lol:
When will you have the outer case prototype milled for us to drool over ? ?
Morten Max
Has thanked: 359 times
Been thanked: 471 times
No one said integrated motor spacers? :lol:
Users browsing this forum: No User AvatarBing [Bot] and 5 guests
