The ultimate Mini JRX2 thread
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Re: Losi Mini JRX2 coming soon
IMHO, the two side body posts are adequate.
- Has thanked: 1129 times
- Been thanked: 3917 times
Functionally yes, but it just doesn’t look right unless it has that itty bitty body mount stud
- Has thanked: 100 times
- Been thanked: 205 times
Working on the molded chassis at the moment but thought I would toss up the WIP body mounts, I have not modded anything so it is unlikely a screw is going to fit in the adjustable part of the front one... but that is what drill bits are for! Have fun lol
https://cults3d.com/en/3d-model/game/losi-truck-style-body-mounts-for-the-mini-jrx2-work-in-progress
updated chassis pic heh...
Going to do the h-arms after the chassis, although I need to get a set of hinge pins and rear links to make sure I get them right.
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- Has thanked: 184 times
- Been thanked: 63 times
Great work!!!clm wrote: ↑Thu Jun 16, 2022 12:24 am Working on the molded chassis at the moment but thought I would toss up the WIP body mounts, I have not modded anything so it is unlikely a screw is going to fit in the adjustable part of the front one... but that is what drill bits are for! Have fun lol
The front kickup has not been sized right and I have not modeled any holes yet but dang if the trans and battery holder did not drop right in! Yes Yes I know I still need to do the bellcrank mounts, this was just a sizing test
There are some mounting holes by the rear bulkhead that got overridden by the longer length of the mini rear bulkhead, I only ever knew these to be used by the RPM esc mount so I will probably slide them forward a bit.
Oh on another note... the junior chassis with no ribbing on top is exactly the same layout as the T and the Pro for the most part.. I bet it would be flimsy but you could do a shelfer lol
Edit#2 the junior chassis is only very slightly different then a LXT/ProSE chassis, trim the sides, extend the tail one hole length..
- Has thanked: 1153 times
- Been thanked: 624 times
Added silver Mini T 2.0 springs. Drained the oil out of the shocks and removed esc for a cleaner look.
-Brad
Make nylon wheel nuts! Take a regular 4-40 nut, drill center out with a 9/64 bit and thread on.
-Brad
Those look great. I picked up some 6/32 to use but they still didn’t look quite right. The 4/40 are perfect
Now you need to find some 2mm for the shocks
I got the idea from you and just looked around at what I had..lol
-Brad
You could always print some nylon nuts if push comes to shove
- 3843 Views
Last post by mtbkym01
- 37 Replies
- 14966 Views
Last post by jcwrks
- 1598 Views
Last post by JK Racing
- 31 Replies
- 6817 Views
Last post by Lavigna
- 2590 Views
Last post by RC10th
- 1304 Views
Last post by isaidme
- 28 Replies
- 3884 Views
Last post by Heffay
- 90 Replies
- 16444 Views
Last post by huminski
Users browsing this forum: Google [Bot],
Tbot [Bot] and 2 guests
