FWD-GT TOP SPEED CAR
- romulus22
- Has thanked: 902 times
- Been thanked: 790 times
Re: FWD-GT TOP SPEED CAR
Ill be honest I was hoping this would be much faster than what I've gotten it to so far. My old SC10 with the Traxxas brushless setup on 3s was reaching the same speeds by radar gun. The SC10 floated a lot at speed but I didn't crash it but maybe a few times.
- romulus22
Just checked the settings on the ESC. Apparently I set the drag brake at 60%
oops
everything else to my knowledge looks like its setup to have full power in forward. Even a setting in there for normal or reverse motor rotation. So I switched that and matched the colors back up at the motor. Hopefully going to take it out here in a little bit if the weather holds out for some testing with the original gears.
- romulus22
Well its official. This car is impossible to keep straight when the wheels are not pulling it forward. Even with the drag brake at 0 it still goes sideways and flips. So.... Another body destroyed. I did do one kamikaze run no body to see what would happen. Car stayed perfectly planted the whole time. And managed my fastest run no body. And on the return trip it was pulling hard. Some how either the bone popped and broke the arm or the arm just finally let go.
Screenshot from the onboard phone
- slotcarrod
- Been thanked: 45 times
CRAZY FF DUDE!
I wonder if that's a FF world record?
Rod Littau
- Has thanked: 1134 times
- Been thanked: 3934 times
Time to add another gearbox! Don't give up yet. You could always add a mechanical brake for the rear wheels but if your gonna add weight might as well add a gearbox. Instead of dual motors you could possible add a pulley to the slipper (by where the brake nut went?) and drive the rear gearbox that way.
I tried fwd drag slot cars and had a great issue at the end of the track also. When it hit the vht and full brake the back end would come around and the guy behind the counter would have to duck or get hit lmfao
- romulus22
Good news and bad news.
Bad, by time I got to my new spot. With the storm rolling in. Its near pitch black out here. Secondly. Three runs. GPS never started
The good. This thing is wicked fast on 6s. Even better. It is so planted and easy to control with the body off.
I made three passes with an all black car in this. Wish it wasn't going to storm all day tomorrow
Incase anyone was wondering what it weighs now on 6s
- SFC K
- Has thanked: 47 times
- Been thanked: 9 times
Nice work! you are finally on to something wit the 6s.
I kind of thought weight was an issue. That sucks the GPS did not start up. You probably broke your last speed run.
Jeff
- romulus22
SFC K wrote:Nice work! you are finally on to something wit the 6s.I kind of thought weight was an issue. That sucks the GPS did not start up. You probably broke your last speed run.
Oh I know for a fact it broke my 77.4, but by how much..... I was pretty mad at my phone and the whole getting dark at 5:30. When I was at the end of the strip I couldn't even tell which way the car was pointing. I has to slowly give it throttle and see which way the small black dot was going. If it wasn't going left or right I figured it was coming at me so I got on it. One of the hardest things I've tried to do in a while. And as far as weight being an issue. I didn't think how little this car weighed would be an issue at all. I'm honestly surprised this car didn't do 100 on 4s with how little it weighs.
- LoboNYC
- Has thanked: 880 times
- Been thanked: 356 times
I couldnt believe how light that car is...i thought i was reading your scale pic all wrong...i cant believe that damn pinion gear
Did you run the lexan bottom without the body or was it the car as in pics?
- romulus22
I broke the lexan under tray the first run out. Been running without it since. The car as you see it on the scale is how I ran it tonight when it drove better than it ever has.
- Diamond Dave
- Has thanked: 699 times
- Been thanked: 130 times
That's why I chose a cut-up GT2 body for my speedster.I did do one kamikaze run no body to see what would happen. Car stayed perfectly planted the whole time. And managed my fastest run no body.
Of course, I need the flow-through to cool the nitro engine, or I probably wouldn't have a gaping hole in the windshield.
Just enough to protect things, but doesn't catch wind and lift the vehicle up. I've found it difficult to achieve sufficient downforce in the right places to counter a body that is acting like a parachute at 80+ MPH. Maybe if we had access to wind tunnels..........
What you need to find if a very aerodynamic body that is long and narrow, leaving the wheels and arms exposed. Basically like an airplane fuselage.
- romulus22
Pretty much, yeah.
As an aside, I finally got around to doing break-in on that Nova. Yeah....gonna need to block off that hole and/or run a hot plug. Highest temp I saw was 181*F, was consistently between 130*-150*. I like to keep 'em cooler during break in, but that is flat out cold.
- 4051 Views
Last post by Lonestar
- 53 Replies
- 5893 Views
Last post by RC104ever
- 1548 Views
- 812 Views
Last post by SWAZ RC
- 2730 Views
Last post by RC10th
- 1056 Views
Last post by clinehobbies
- 610 Views
Last post by m_vice
- 73 Replies
- 7613 Views
Last post by Dadio
