Lohas has essentially remade the tecnacraft wheel
vintage AE
Has thanked: 29 times
Been thanked: 36 times
Re: Lohas has essentially remade the tecnacraft wheel
Post by vintage AE »
I think it was posted in a single thread in here already, just read through it and you will see it :lol: :P
RC10Sprinter
Post by RC10Sprinter »
Fronts
2 X 3/16 x5/16 flanged bearings.
then you will need a couple washers 3/16 inside diameter, or a couple rubber o rings, or a 3rd non flanged 3/16 x5/16 bearing. The 3rd bearing will probably make your wheel stick out a couple mm. the spacer of your choice should go on the inside, but that is pretty self explanatory.
Rears
On the inside use the hex adapter.
On the outside use a 5/32x5/16 unflanged bearing.
Hope this helps
Synergy
Has thanked: 127 times
Been thanked: 72 times
Post by Synergy »
I did as above but used bronze bushes on the rear and as spacers on the front, they were left overs from my Astutes, not sure on size.
Here's my TC Showroom
greene-r74
Post by greene-r74 »
I was trying things last night and I found that the flanged bushings for the front work great for the rear rims. It plugs in and has a nice flange surface for the nut to tighten up on. Only problem is that I only have one of them.
Rizzo
Post by Rizzo »
Please help again!
I got myself some 3/16 x 5/16 bearings which now fit the wheels fine, but they are too small internally to go over my axles! What the hell am I doing?
regards
Jak
"Don't underestimate the power of a backhander. They F&^%ing hurt" SuperWog
Has thanked: 359 times
Been thanked: 470 times
You bought the bearings for pan car axels-
murphy3428
Post by murphy3428 »
Rizzo wrote:Please help again!
regards
Jak
It also looks like you have the loha's spacer infront of the center it should be mounted behind the center
Rizzo
Post by Rizzo »
I like the wheels with the deep dish look, it makes no difference to the fitting.
Are these the bearings I need?
http://cgi.ebay.com.au/1-8x5-16-x9-64F-Metal-Shield-Flange-Ball-Bearings-/310285986258?pt=Radio_Control_Parts_Accessories&hash=item483e7c69d2 1/8x5/16 x9/64F Metal Shield Flange Ball Bearings
jak
flipwils11
Been thanked: 19 times
Post by flipwils11 »
Getting ready for my next shelfer build. I had my Lohas wheel centers annodized blue.
Those look very nice, I was toying with the idea of doing the same with a set of the hurricanes if he remakes them in the future- great blue!
Synergy
Post by Synergy »
Wow they look great, I've got a Tekin that they would be killer on :wink:
fordtransman
Post by fordtransman »
That blue is awesome. Now I'm inspired to build an entire car around them.
CNA75
Post by CNA75 »
Yup, those blue centres look the business! That's why I purchased my silver set to keep my options open.
flipwils11
Thanks guys, this will be for my soon-to-start B3 Factory Team build. I sent a blue FT motor plate for the color match.
Here are the other parts that went in at the same time (btw my guy will strip the old anno for you so there's little or no prep work required on your part):
My next anno runs will be in purple and then green.
once again, that is a really really nice blue!
