Vintage AE Ad -- 1979 RC12E "Go Racing With The Team"
- clinehobbies
Re: Vintage AE Ad -- 1979 RC12E "Go Racing With The Team"
In the last picture of the Radicon mag there is a plastic chassis in the lower rigt hand corner do you have any info on that type of car?
Have a nice day!
- WC1982
- Been thanked: 15 times
I didn't experiment much with custom graphite until the late 80's. In the early days we took what we could get, selecting different thickness plates from the production parts. For a long time I think all of the graphite for RC cars was reject material from aerospace production. By the time there were manufacturers willing to experiment with different layups I was mostly into oval and my on-track results were always better with a soft chassis so I was happy with the stock parts. Graphite seletion wasn't an area that paid off for me in terms of results, so I spent a lot more time on motors,batteries, charging, dynos, brushes etc.Dirtdiver wrote:Kent-
What year did you first start experimenting with carbon fiber layups for the chassis and did this development lead to any carbon fiber/kevlar or carbon fiber/spectra chassis layups?
Thank-you
dirtdiver
- WC1982
Those were Lexan chassis that some of the UK drivers used. I don't remember the brand name of the car but I think they had problems because the weather in SoCal was extremely hot for that race which made the chassis flex too much.clinehobbies wrote:In the last picture of the Radicon mag there is a plastic chassis in the lower rigt hand corner do you have any info on that type of car?
- kenooze
The lexan car was the first Schumacher 1/12 scale car, just before the C Car.
Also SG Italy also made a lexan chassis. probably called Gemini. THe rcmagvinatge ebsite has its image. http://www.rcmagvintage.com/reviews/retro/voitures/electrique/musee/sg/sg.htm
In what years/circumstances that the wing on the motor mount was abandoned?
- WC1982
When the 12L came out we stopped using rear wings. Improvements in tire technology and the grip of the T-bar design gave us enough traction to run without them.polarbear wrote:In what years/circumstances that the wing on the motor mount was abandoned?
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 471 times
My Kyosho Bluebird had a red Lexan chassis, don't think it was ever a competitive car thoughpolarbear wrote:Also SG Italy also made a lexan chassis. probably called Gemini. THe rcmagvinatge ebsite has its image. http://www.rcmagvintage.com/reviews/retro/voitures/electrique/musee/sg/sg.htm
Also to Kent and Bud, we have a Vintage On-road Nats in TN coming up in mid Feb if either of you
are interested--
- Bud Bartos
- Regular Member
I never Knew You ran the flywheel pinion back then ???? I thought Parma was the only one running them. See what You learn after 25 yearsWC1982 wrote:Yep, that's true about the pinion. I was TQ in stock and ran the same Danish coin on my pinions for that race. I think Bud saw me running them and did the same. My idea for doing that was an evolution of the superlight pinion gears that had just been released. I noticed that in stock the lightweight pinions made the car feel slow, and the heavier steel pinions gave me a lot more punch and faster lap times. Thinking "more is better" I used a reamer to enlarge the hole in the coin and glued it to the pinion. And it worked on those motors. I think it had something to do with the armatures being very lightly packed. That was just about the end of Stock class racing for the pros, so I didn't use the heavy pinions much after that, but I still have them in my pit box
- HotRodJosh
- Has thanked: 3 times
What an awesome thread!
Great story about tire compounds....racing on carpet in AK, my pops and I found out that common lamp oil worked very well, heck, we had a bunch of it for keeping the house lit during power outages during the winter...haha!
It's cool to see alot of the racers guys like me looked up to during the 80's here ...
"I've got a fever, and the only prescription.....is more cowbell."
Pinstriping by Josh
Pinstriping by Josh
for info , here is my SG gemini with lexan chassis
WC1982 Kent, it sounds to me that the lightweight resistor speed control was not in the product list of AE but Parma. Am I correct?
By the way, anyone knows if the standard size resistor now available from Parma nowadays (under slot car controller section) the same as we used in the 12E?
Thanks Kent . So what do you think is the best mechancial speed control at big races??
I know and used the "Reedy's trick" by adding a wiper at the full speed position to ensure best contact. Some used a BIG micro switch there, some used the short side of the resistor to get more punch power..... and thicken the wiring...
While we have the various FET technologies in the past 20 years, was it a "one-best design" at that time in big races???
For the variant of chassis cutting of 12E, do you feel there are significant differences? I mean the standard "I" shape, "A" hole in front of motor; milk bottle shape and even DA graphite blank etc. I found the tightening of the front grommet was effective in the flexi difference rather.
On the other hand, the original AE chassis was made of epoxy plate while the Yokomo's was green FRP which was stiffer and heavier.
- 1136 Views
Last post by lifeIsAnalog
- 4718 Views
Last post by PlastiZapCA+
- 1450 Views
Last post by mytimac
- 646 Views
Last post by Dangeruss
- 1817 Views
Last post by Dadaman
- 3742 Views
Last post by drover
- 2232 Views
Last post by Eau Rouge
- 888 Views
Last post by Phin
Users browsing this forum: AYKBOBCAT,
Tbot [Bot] and 4 guests
