EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
Phin wrote: #5 looks to be a diff hub that doesn't use screws to mount the wheel.
Corally used clips to mount their older wheels. So maybe Corally?
#12 is kind of like #11 but it fits a 5mm axle and has a 3mm hole for the axle thread.
I still think this might be a spur holder. The 5-to-3 mm axle hole screams "layshaft". Possibly for proprietary spurs?
#17 - A&L Lethal Weapon diff parts? Or extenders that fit over #16?
#18 could also be for body posts.
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Cool, I'll look at some Corally cars for #5.
#17 definitely don't belong to an A&L Power Clutch...I had one of those.
#16 are the left side hubs that pair up with the #6 diff hubs. They have the same hole pattern as #17, #12 and the two hubs below #12...and I think maybe that hole pattern might match up with the 3 hole Mini-Mag wheels. #16 are also for a 6mm shaft so maybe they're for a Kyosho pan car?
It occurred to me yesterday that #11 might be for a drag racer/funny car and #12 might be for a monster truck.
I don't know if it's alright to post links to eBay auctions that have ended here but there are more pics of the hubs there. If you want to take a look at them I can PM you the link.
And thanks for the help. :D
V12
Been thanked: 100 times
Post by V12 »
regarding #5
yes Corally cars are using clips for securing the wheels at their own Corally system, but this system doesn´t use aluminium hubs but plastic drive plats.
There also is an US style system for Corally cars, but these hubs are using screws as any other cars, no clips.
AscotConversion
Has thanked: 43 times
Been thanked: 56 times
Post by AscotConversion »
Edit: I found my answer...sorry :oops:
AscotConversion
I think a lot of those hubs with 3 holes are RC500 stuff...
Phin
Post by Phin »
Did the RC500 use metric sized shafts? The 3 hole hubs have either a 5mm, 6mm, or 7mm inner diameter.
Now that you mention it though #17 does look like something off a gas engine....maybe a flywheel/clutch part?
AscotConversion
I'm no expert, but a lot of the RC500 stuff seems to have 3 pins, check out this manual shot...2 speed is 3 pins as well..???
civilguy
Has thanked: 5 times
Been thanked: 14 times
Post by civilguy »
Ok, I have been cleaning out boxes of stuff and stumbled on this. Anyone know what it may be? All I know is it's shiney, pretty and new. The box had Clod parts and pan car parts (but that may not be of any help). I am thinking some sort of Clod mount, but am likely completely off.
Jeff
Been thanked: 1319 times
i think that's a trailer or sled pullling hitch for a clod buster.
civilguy
Post by civilguy »
scr8p wrote:i think that's a trailer or sled pullling hitch for a clod buster.
OOOOOH... that makes sense. I was trying to mate it up to the Clod axles and also trying to turn it around to make it mount on a RC10L... neither with great success. :oops:
Maybe it mounts at the bumper somehow.
Thanks! Now off to see if I can find more info online.
EDIT: the internet is amazing when you know what you are looking for!
http://www.robobugs.net/galleries/rc-models/tamiya-clodbuster-custom
A few pictures down there is a non-gold version of it. Thanks again!
Jeff
Lowgear
Has thanked: 121 times
Been thanked: 796 times
Post by Lowgear »
Its made by a company called MaxTrax which was a division of Hobbico. If it doesn't fit the Clod, than it could be the Midnight Pumpkin / Lunch Box or Blackfoot version.
civilguy
Post by civilguy »
I've managed to ID a lot of stuff but I am tired of searching the web... especially when there's no nudity involved. :lol:
These are magnetic... some sort of mount, but what?
Lexan cover for ?? (msc?)
Thanks!
Jeff
Has thanked: 1737 times
Been thanked: 1145 times
civilguy wrote:Lexan cover for ?? (msc?)
Thanks!
The 58087 molded into it is the giveaway.... Tamiya Manta Ray MSC cover.
civilguy
Post by civilguy »
Thanks Alex... like I said I am tired of searching. I bet it goes with this:
Jeff
Lowgear
Post by Lowgear »
civilguy wrote:I've managed to ID a lot of stuff but I am tired of searching the web... especially when there's no nudity involved. :lol:
This is an odd occurrence. A couple of days ago I pulled a box out of the crawl space full of old computer stuff that I hadn't seen since the late 90's. I went through it before bringing it out for garbage and there was one of those black cylindrical things in it. I thought what the heck is this thing? It was magnetic but the field was very weak so I chucked it back in the box.
Return to “Identifications”
