Not today, but yesterday, i was working on my Lola T310 Cockpit and motor bay...
Today---> printing
Tomorrow, first test
Jerome
Frankentruck wrote: ↑Wed Oct 30, 2024 9:59 pm It seems like the spring, washers, and brass spacer for the washers are the hardest to find. The 5-40 nut is available from Custom Works, otherwise it would be hard to find.
So turns out the original stealth top shaft threads had been partially stripped and worn down, so need to get a new top shaft. In this case with also needing a slipper assembly, would it be ideal to switch to a different style top shaft and slipper assembly? Perhaps the B4 or something else? I'm not aware of any other top shafts that can be used and fit in the stealth on the RC10.
Thanks. I've been keeping an eye on Liveaxle's thread and considered that avenue. I do have B4 slipper pads, a bunch of spur gears, nut and spring, so all I'd need are the hubs.GoMachV wrote: ↑Sat Nov 02, 2024 7:30 pm You could use the avid top shaft and avid clutch, liveaxle just posted about going over to that system. https://www.rc10talk.com/viewtopic.php?t=50088
Also since kits are now being parted on eBay, you could just grab the new parts off a rere if you want to keep it vintage style.
I go both ways on the subject. Sometimes I like them tight, sometimes I like them exaggerated.Frankentruck wrote: ↑Sun Nov 03, 2024 4:09 pm My son is going to be my co-driver. He says "Trim the body mounts, dad."
I love that shade of blue!Frankentruck wrote: ↑Sun Nov 03, 2024 4:09 pm My son is going to be my co-driver. He says "Trim the body mounts, dad."
Thank you, TRX! The rings are not keyed on this model. They are just held in place by the CA.TRX-1-3 wrote: ↑Mon Nov 04, 2024 7:12 pm @1911Colt Are the rings keyed to the outdrives at all? If it's just CA, it seems plausible that they just sheared away at the glue-to-outdrive interface. I chipped a top gear on turf with a slipper once. Just the right combination of conflicting inputs and WHAMMY!
Users browsing this forum: Semrush [Bot] and 4 guests
