So, what did you do RC today?
Has thanked: 3699 times
Been thanked: 1980 times
Yesterday, technically. Made a couple of trips to a park near my cousins. Did some good running. I have a couple of vids I'll post later. That GT rips with the .15 OS in it! No video of that, unfortunately.
RogueIV
Has thanked: 2135 times
Been thanked: 1100 times
Post by RogueIV »
Race day at RCM
Has thanked: 2604 times
Been thanked: 2977 times
I worked on this Race Prep that needed a little cleaning.
1911Colt
Has thanked: 1782 times
Been thanked: 859 times
Post by 1911Colt »
THEYTOOKMYTHUMB wrote: Sun Oct 27, 2024 12:30 pm Yesterday, technically. Made a couple of trips to a park near my cousins. Did some good running. I have a couple of vids I'll post later. That GT rips with the .15 OS in it! No video of that, unfortunately.
:D
R6cowboy
Has thanked: 871 times
Been thanked: 903 times
Post by R6cowboy »
What are slipper options for an original stealth trans which has the top shaft with the roll pin that the inner slipper hub sets in?
-Jerry-
Do you need the entire slipper assembly? The B2, B3, T2, GT, and T3 slipper should fit.
It seems like AE should be offering the slipper assembly soon. The rest of the 10T rere gearbox parts are already available.
R6cowboy
Post by R6cowboy »
Frankentruck wrote: Wed Oct 30, 2024 9:29 pm Do you need the entire slipper assembly? The B2, B3, T2, GT, and T3 slipper should fit.
Indeed I do need the entire slipper assembly.
-Jerry-
It seems like the spring, washers, and brass spacer for the washers are the hardest to find. The 5-40 nut is available from Custom Works, otherwise it would be hard to find.
Has thanked: 269 times
Been thanked: 2094 times
Frankentruck wrote: Wed Oct 30, 2024 9:59 pm It seems like the spring, washers, and brass spacer for the washers are the hardest to find. The 5-40 nut is available from Custom Works, otherwise it would be hard to find.
RJ Speed has the thin 5-40 locknuts.
R6cowboy wrote: Wed Oct 30, 2024 9:19 pm What are slipper options for an original stealth trans which has the top shaft with the roll pin that the inner slipper hub sets in?
Original, B/T3, and eliminator. Maybe A&L.
Been thanked: 3917 times
A&L never did a slipper for stealth, it was pretty much the same thing so no reason to
morrisey0
Has thanked: 87 times
Been thanked: 1853 times
Post by morrisey0 »
Finally got into the build of my RC150.
Not very exciting, but since it's a slow news night, I cleaned out a "Junk" drawer in the laundry room as my wife calls them. Deals in the catalog are good thru April 30, 2010 if anyone is interested. Andy's arms were not in there, which is disappointing. I have some plans for them if they turn up.
R6cowboy
Post by R6cowboy »
THEYTOOKMYTHUMB wrote: Fri Nov 01, 2024 10:54 pm Not very exciting, but since it's a slow news night, I cleaned out a "Junk" drawer in the laundry room as my wife calls them. Deals in the catalog are good thru April 30, 2010 if anyone is interested. Andy's arms were not in there, which is disappointing. I have some plans for them if they turn up.
Dang, the T4.1 was only $234.99. Can't make out what the Duratrax Evader deal was, but had to be cheap.
-Jerry-
$120 RTR. :shock:
Users browsing this forum: No User AvatarDotNetDotCom.org [Bot], No User AvatarGoogle Adsense [Bot], No User Avatartimjz, User avatarXLR8 and 3 guests
