So, what did you do RC today?
- Has thanked: 268 times
- Been thanked: 258 times
All wires organized right. Crystal and receiver in the right spot. Falcon done.
- ZED32
- Has thanked: 166 times
- Been thanked: 242 times
Made some custom chassis protectors out of vinyl for my sassy chassis king cab. The letters for the apm sticker were cut on a brother scan&cut (hate that thing), the flames were hand drawn and cut with a razor blade
- Lavigna
- Has thanked: 1099 times
- Been thanked: 1418 times
Thanks to Charlie for this Protoform Ripper X body. It's my favorite body for a Losi XX. This one is an OG still clear wrapped with wing.
I searched EBAY for a new restoration project most of the morning and came up empty
- Has thanked: 1783 times
- Been thanked: 860 times
I've been driving a Top Cat or one of my Cougars around a makeshift track in the backyard pretty much every day this week.
No jumps, dry, dusty, slick as an oily marble. Sliding everywhere... dirt flying....
It is the total opposite of what I should be doing given that I need to prepare for a vintage race on clay.
- ZED32
Soldered some new wires onto a Trinity Monster Tri Rotor motor. Anyone know how many turns one of these is? Gotta be pretty low turns, its absolutely savage in my king cab. Power delivery is just instant and theres torque for days. But, it also seems to make everything overheat, and I dont really know how to fix that.
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
Have you tried just gearing it down a couple teeth? Might need a wheelie bar at that point though.ZED32 wrote: ↑Wed Oct 23, 2024 6:33 pm Soldered some new wires onto a Trinity Monster Tri Rotor motor. Anyone know how many turns one of these is? Gotta be pretty low turns, its absolutely savage in my king cab. Power delivery is just instant and theres torque for days. But, it also seems to make everything overheat, and I dont really know how to fix that.
Are pinion changes simple or do you have to change the spur/counter gear also, like some (most?) Tamiya stuff?
- ZED32
Honestly no idea. I'll look into that though. No wheelies either. Just massive rolling burnouts.TRX-1-3 wrote: ↑Wed Oct 23, 2024 7:10 pmHave you tried just gearing it down a couple teeth? Might need a wheelie bar at that point though.ZED32 wrote: ↑Wed Oct 23, 2024 6:33 pm Soldered some new wires onto a Trinity Monster Tri Rotor motor. Anyone know how many turns one of these is? Gotta be pretty low turns, its absolutely savage in my king cab. Power delivery is just instant and theres torque for days. But, it also seems to make everything overheat, and I dont really know how to fix that.![]()
- 1300GT
- Has thanked: 486 times
- Been thanked: 406 times
I was supposed to finish the berm, but got sidetracked by building the tabletop jump which was finished today. Kyosho Optima for size reference.
Chris.
Toys.............they are!
- TRX-1-3
Not sure if it’s possible with a Sassy Chassis, but there is a way/conversion that allows the Stealth trans. to go in a King Cab.ZED32 wrote: ↑Wed Oct 23, 2024 9:09 pmHonestly no idea. I'll look into that though. No wheelies either. Just massive rolling burnouts.TRX-1-3 wrote: ↑Wed Oct 23, 2024 7:10 pmZED32 wrote: ↑Wed Oct 23, 2024 6:33 pm Soldered some new wires onto a Trinity Monster Tri Rotor motor. Anyone know how many turns one of these is? Gotta be pretty low turns, its absolutely savage in my king cab. Power delivery is just instant and theres torque for days. But, it also seems to make everything overheat, and I dont really know how to fix that.
Have you tried just gearing it down a couple teeth? Might need a wheelie bar at that point though.![]()
Here's a look for starters
https://www.rc10talk.com/viewtopic.php?t=40671&hilit=Stealth+transmission+king+cab+conversion
- ZED32
That's the dream for a king cab build. For now I have an avante geared diff in it. Works awesome and retained the original transmission. The trans had a Robinson spur and 18t pinion in it. I swapped those for the stock spur and pinion, as well as added an esc fan and the problem seems to be solved. Barely gets warm anymore.TRX-1-3 wrote: ↑Thu Oct 24, 2024 8:30 am
- Has thanked: 1129 times
- Been thanked: 3919 times
Yeah, Durb gave me the files and we changed things around a bit to make them more affordable. They wont work with the sassy tho
- 1300GT
More track progress. The pictures were taken from the roof. The driver's stand when built will be a lot closer. The good news is when driving you face South. No sun in your face at any time. The straight and berm are 3.5 metres wide. The track narrows after the berm to 3 metres wide until the main straight. Track direction is clockwise.
This is the Eastern end of the track. The centre. This is the Western end. Still have to lay down the remaining hose to outline the straight and berm. A small jump will be added halfway down the straight and possibly another after the lefthand turn beyond the tabletop.
Chris.
- 5572 Views
Last post by Dr. Robotnik
- 20 Replies
- 10396 Views
Last post by cas22
- 6475 Views
Last post by Synergy
- 6693 Views
Last post by ireg
- 5728 Views
Last post by clm
- 2721 Views
Last post by mrlexan
- 2427 Views
Last post by DHood
- 2574 Views
Last post by Winger
