#6002 - RC10 Worlds Car Kit
stulec52
Re: #6002 - RC10 Worlds Car Kit
Post by stulec52 »
What's the process to get a replacement ?
I also think I need a front shock body as one of mine I couldn't get the cap to go on.
Even tried to clean the thread by using a metal cap
knixdad
Post by knixdad »
Just email support.
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Post by RichieRich »
Hey guys. I just started my build this evening. I made it to the transmission assembly and I definitely have a problem. When I put the case halves together, I can't spin the tranny by hand without feeling tons of resistance. I'm not sure if I have the top shaft problem or a warped case. I'm calling AE in the morning. :?
slow_jun
Post by slow_jun »
is there any email address we could send to for these types of issues with AE? coz I want to claim a replacement parts also for this issue.
TIA.
― Confucius
NickTheGreek
Post by NickTheGreek »
It's the top shaft AND a warped case....but what do I know.
AE's customer support is great and they'll send you one express....
I think something's up with the case...The gears seem to spin perfect by hand with the case open, but once you snap it down, that's when you start noticing problems.
I got lucky that I had bought two stealth kits n popped one of those in instead.....n a brother hit 50 on the nose yesterday on 2s.
.....as far as my personal solution for what seems to be the tranny case being too tight and feeling resistance in the gears...... Stick that tranny in this runner I'm building, fit it with 3s ..Gear up...throw a lil weight on the nose ...lay it down on the concrete, turn it on......n give that sumbich full throttle.
TUCRACEMAN
Post by TUCRACEMAN »
RichieRich wrote:Hey guys. I just started my build this evening. I made it to the transmission assembly and I definitely have a problem. When I put the case halves together, I can't spin the tranny by hand without feeling tons of resistance. I'm not sure if I have the top shaft problem or a warped case. I'm calling AE in the morning. :?
I'm having the same issue. Update us on what they say.
~D
Sent from my XT1053 using Tapatalk
No, I will not help you with your dorky short course truck…sorry, it’s against my religion. If it's not a 1/10 scale buggy...I don't care.
RichieRich
Alright, I called AE and they told me that there is one tooth on the idler gear that is too tall. This causes the tightness in the transmission. Running it should force the gear to conform. As for my top shaft, I finished the transmission assembly and I have no clearance issues. So, I think I'm good. I guess there's going to have to be a bit of a break-in period. :twisted:
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
I see toothpaste and a drill/dremel in your future...
RichieRich
JK Racing wrote:I see toothpaste and a drill/dremel in your future...
Yeah, probably. Does anyone know if the 9360 idler gear is the same thing as the 6569?
Bottom Feeder
Has thanked: 13 times
Post by Bottom Feeder »
Negative. 28 vs 26 teeth.
jfive
Post by jfive »
Hi everyone, this is my first post. i most actively in RCtech. I found this site after getting a rere worlds car and ran into the stealth meshing problem like most. after reading all the post, i realised i wasnt the only one and my top shaft is also too short. luckily i didnt have any cvd issues.
The meshing issue was driving me nuts, as there is no way it could be run in. I spoked to a few of my mate who is actively racing in Aust to see if i could find someone to make me a new idler gear. And one of them refered me to a fella in UK.
after describing the issues of the stealth gear box and giving the specs, he was able to make me a new idler gear. and the result was a miracle! the new idler fitted perfectly and i dont even have to change ratios.
i am so excited i wanted to share this with you all. i know this is the solution we all been waiting for.
His contact details will be posted as saon as i have his approval in the next day or so.
and here is the pic of the idler gear.
RichieRich
Nice. This makes me wonder why AE is not replacing the idler. :?:
slow_jun
Post by slow_jun »
Guys,
whats the email of AE? mailed them here [email protected] but no reply.
TIA.
― Confucius
jfive
Post by jfive »
RichieRich wrote:Nice. This makes me wonder why AE is not replacing the idler. :?:
only one thing comes to mind.....$$$
hondaman
Post by hondaman »
slow_jun wrote:Guys,
TIA.
A couple of pages back (well back on page 59) this was discussed and this is who I sent my email to. Here it is: [email protected] . Don was great and helped me out.
Shawn
