#6002 - RC10 Worlds Car Kit
- mtbkym01
- Has thanked: 190 times
- Been thanked: 276 times
Re: #6002 - RC10 Worlds Car Kit
This has probably been asked on the forum before but I struggled to find anything, but are these thunder tiger wheels the same as on the Worlds Car, but obvoiusly in white?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXALSD
Cheers
Cheers
- slotcarrod
- Been thanked: 45 times
I do believe they have a close offset, but not 100% sure they are the same! They will fit for sure, but may be a tiny bit narrow.
Rod Littau
- mtbkym01
Ok, it's all good, I managed to source some AE's ones in white anyway, so it doesn't matter now anyway, cheersslotcarrod wrote:I do believe they have a close offset, but not 100% sure they are the same! They will fit for sure, but may be a tiny bit narrow.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
The Thunder Tiger wheels are the ones I have used for the past couple years. They work perfect and are the right offset.
- mtbkym01
Good info to know, cheersJK Racing wrote:The Thunder Tiger wheels are the ones I have used for the past couple years. They work perfect and are the right offset.
- mtbkym01
Have also ordered some 5 spoke JC Racing wheels, may consider dying a set black to see how that will look on my "pink & white" worlds
- GodSpeed
You can order the JC Racing 5-spokes in black, white and yellow....can't you?mtbkym01 wrote:Have also ordered some 5 spoke JC Racing wheels, may consider dying a set black to see how that will look on my "pink & white" worlds
- mtbkym01
I only thought of it after I ordered the wheelsGodSpeed wrote:You can order the JC Racing 5-spokes in black, white and yellow....can't you?mtbkym01 wrote:Have also ordered some 5 spoke JC Racing wheels, may consider dying a set black to see how that will look on my "pink & white" worlds
Re: #6002
Code: Select all
lol..same here and I promised myself that the re-re classic would be my first and last AE car. My wallet won't allow me to get one yet but hopefully the fact that the WC is not a limited release will at least give me an opportunity to purchase one in the future....maybe.sandkil wrote:I'm running out of space... honestly!! But i have to buy one... have to..![]()
Hey
So I had the problem with the top shaft in my build.
It felt horrible to turn the gearbox over by hand.
Anyway I got a new b4 top shaft to replace it.
But it doesn't fit.
Oh it's the MIP part if that makes any difference.
What am I doing wrong here?
Thanks
But it doesn't fit.
Thanks
- JK Racing
the MIP top shaft for the B4 has the spacer built into the shaft. the AE part the spacer is separate. for the stealth, the spacer is not needed...so the MIP shaft does not work
Ah.
Ok, well that explains it
Thanks JK
Fortunately I have a B4.2, so I guess I can just swap the MIP one into that car.
Thanks JK
I also had the top shaft issue - inner slipper hub rubbed on the motor plate and the transmission was rough.
AE sending me a replacement.
- 2766 Views
Last post by sandkil
- 1056 Views
Last post by carloco8
- 4320 Views
- 2089 Views
Last post by XLR8
- 866 Views
Last post by RogueIV
- 1534 Views
Last post by AndrewCooke
- 1181 Views
Last post by ASC6000
- 2468 Views
Last post by mytimac
