- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Custom cut a new chassis out of CF or G10 with an offset battery tray then mount a NASCAR body on it.
EDIT: Does look like there's a ball diff for it - http://traxxas.com/sites/default/files/4210_explodedviews_transmission-2001.pdf
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Just what I was thinking - together with a set of wide rearsPhin wrote:............................... then mount a NASCAR body on it.
Gone fishing
I had a quick peek in the gearbox, it looks like meant to have a diff yes.. except it's been glued together solidPhin wrote:Custom cut a new chassis out of CF or G10 with an offset battery tray then mount a NASCAR body on it.
- Phin
With a locked diff and a DD tranny I'd feel compelled to put staggered foams on it and see how it fairs against pan cars on an oval track.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
They were traxxas' attempt to run onroad before the 4tec was released IIRC. Not for sure of when it was out but I remember seeing these sitting next to the DS at one of the long gone LHS. They were definitely a cheap alternative to the DS at the time but they still sat on the shelf longer than a DS did
. It would be a fun basher for sure...doesn't seem to be missing much.
- drbelleville
- Been thanked: 4 times
klavy69 wrote:They were traxxas' attempt to run onroad before the 4tec was released IIRC. Not for sure of when it was out but I remember seeing these sitting next to the DS at one of the long gone LHS. They were definitely a cheap alternative to the DS at the time but they still sat on the shelf longer than a DS did. It would be a fun basher for sure...doesn't seem to be missing much.
Hard to believe some one ran one of those at the Insane Speed Run challange, when they started back up! I believe it was in RCCA.
- Lowgear
- Has thanked: 121 times
- Been thanked: 796 times
I had a Street Sport somewhere around 2000. Its the only on-road Traxxas vehicle I've ever owned. I remember one of the biggest cons with it was that the tires were peaked so they had a tiny contact patch. I can't remember if they were an odd size or not which made them difficult to change. Its been a long time and I didn't have the car for very long. I bought it new from Tower and brought it to the night shift job I had at the time and drove it around the parking lot a few times.
According to the Traxxas site it was released in 1997.
- cyberfox
Hi,
Could you help me to identify upper link on this pic (don't take care of red circle, I previously used the pic for something else):
http://otoludic.free.fr/photos-forum/upper-link.jpg
I need to find another one, but I don't know which car it comes from
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
Those are lower yokomo ball cups and upper sway bar ends (yokomo) its 2 parts with a rod in between-
They're still factory yokomo ends, unless the "links" your referring to are the camber links in which case those on that 93' look like Lunsfords to me
- 59 Replies
- 16055 Views
Last post by Diamond Dave
- 106 Replies
- 27070 Views
Last post by mikesofunny
- 431 Replies
- 54321 Views
Last post by Eccentric
- 67 Replies
- 16808 Views
Last post by bearrickster
- 321 Replies
- 41803 Views
Last post by tazz888
- 448 Replies
- 49868 Views
Last post by MelvinsArmy
- 351 Replies
- 47404 Views
Last post by Frankentruck
- 4196 Views
Last post by mrlexan
