looks like we need a rere associated ReRe DS section next!
Everything pertaining to the RC10DS re-release.
RogueIV
Has thanked: 2135 times
Been thanked: 1100 times
Re: looks like we need a rere associated ReRe DS section next!
Post by RogueIV »
XLR8 wrote: Fri Aug 23, 2024 11:34 pm I don't think it's been mentioned but I've found another error with the manual.
Page 14, rear shock install, step 7 shows the shock bushing with the flange toward the tower/bulkhead:
The bushing should be reversed as explained in the original manual (page 32):
After installing one shock per the new manual, it seemed bound-up so I checked the original manual and found the error.
Hey AE, why don't you simply include the original manual with your new kits? Your new manuals are crap.
I'll add that note to my manual. I'm already running mine that way but I thought I needed to because of my full length wheelbase setup.
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
Just finished the transmission and it has a tight spot. I suspect the molded idler gear/shaft and/or diff gear are not concentric but I haven't yet confirm. Top gear is fully machined so it's probably fine. The spot is random so it's probably a combination of things.
Anyone else having this problem?
GreenBar0n
Has thanked: 1271 times
Been thanked: 860 times
Post by GreenBar0n »
XLR8 wrote: Mon Aug 26, 2024 10:02 am Just finished the transmission and it has a tight spot. I suspect the molded idler gear/shaft and/or diff gear are not concentric but I haven't yet confirm. Top gear is fully machined so it's probably fine. The spot is random so it's probably a combination of things.
Did you use a bearing kit? I don't remember this problem, or it wasn't as severe in my case.
XLR8
Post by XLR8 »
GreenBar0n wrote: Mon Aug 26, 2024 4:54 pm
Yes - well, not actually a "kit". I have a box of bearings from various sources.
I've reassembled the trans again and I really didn't find anything wrong.
The sticking isn't severe so I'll just run it a pack or two and if it doesn't free-up, I'll swap the gears with a shelfer car.
Maybe I just got a bad set.
Been thanked: 3917 times
I actually love chasing stuff like that. Since all 3 gears are different tooth count, you can figure out which one it is by the revolutions or just mark a gear and see if it binds in the same spot every time. If not, mark the next gear and so on. Most of the time it's a tiny burr or piece of shrapnel in the metal gear
Brendan2904
Has thanked: 268 times
Been thanked: 258 times
Post by Brendan2904 »
Do you really need to glue the tires if you’re running brushed?
Has thanked: 2604 times
Been thanked: 2977 times
How loose do the tires fit on the wheels?
Brendan2904
Frankentruck wrote: Tue Sep 24, 2024 8:18 pm How loose do the tires fit on the wheels?
They are tight enough. More like Tamiya tension.
Brendan2904
Also am I supposed to glue the gold hubcaps on?
Return to “Associated On-Road Re-Release Forum”
