RE RE STEALTH TRANS
- GodSpeed
Re: RE RE STEALTH TRANS
I still don't have my "correct" parts from Stormer after they sent me a bastardized Worlds Stealth kit when I ordered a 6560 kit.
Numerous unanswered emails now after agreeing to send me a US case, B4 top shaft, US idler and a trans brace (missing). He said it would take about a week, maybe a bit more. It's been a month.
Finally got Bob Stormer on the phone the other day and he said "oh ya, thanks for reminding me. I'll make a note to get some one back on that."
WTF? Not impressed.
WTF? Not impressed.
- jbmeyer13
- Has thanked: 25 times
- Been thanked: 11 times
So here's a shot of a new bulkhead, an original 10T case and a new 10T case. I was considering using peroxide on my original case but after comparing it to the bulkhead it looks pretty good. I'm wondering if the peroxide would alter the color too much?gomachv wrote:The original white cases were phased out long ago when they went to black. If you got an original run of white cases from associated just recently that's a huge score as they bring good money on eBay. All the cases I have got from associated were the new header and the color is described as "Compaq Gray" like the computer.jbmeyer13 wrote:Hmmm...interesting. I just received a 10T stealth case and the color looks to be correct. I'll have to take a look again tonight and compare them closely. How are you differentiating the production runs? I figured any packages with the American flag logo or prior were considered original run.gomachv wrote:The cases from associated are not NOS they are however made from the original mold. The last ones of the originals to come from the factory were black, the newest ones are a grayish color and are noticeably different than original (I have just received 4 of them). I'm not talking about the ReRe worlds cases, they are closer to the correct color but completely different.
- bully
- Been thanked: 6 times
After several messages I am glad to say you can now buy the ASC6565 USA stealth transmission case from Amain hobbies, very happy they got them in and only took them about a week to get them in stock... I also asked Liquid RC but haven't heard anything or seen them on their site yet..
- GodSpeed
With all of the variables in assembling these things due to some parts being considered "good" and some being "bad", I'm not sure if it's ever been mentioned that if you wanted to use a USA case (6565) and a Worlds idler (the one that comes with a separate gear, shaft and two bearings), you would actually need two MORE bearings to hold the shaft in place.
Right?
The bearings you would have are used inside the idler gear and the USA case doesn't have the 'shaft holder' holes moulded into it so the idler would slop around inside. You'd need two more bearings to hold the shaft still in the case.
Right?
- Has thanked: 1081 times
- Been thanked: 3747 times
- GodSpeed
Ya I agree. I don't know why someone would do the scenario I mentioned, but it is possible.....and for reasons mentioned, kinda not.gomachv wrote:Yes, but as I showed in my video the idler is most of the problem
I did just to prove the idlers are out of round- if the old idler could fit the new case I would bet it would be smooth. I think the case is less of a problem and the idler is most of it
- GodSpeed
Well, I think you're probably right about that.
I also just found out 'the hard way' that my original gold anno motor plate is short one hole for mounting a Stealth tranny.
And speaking of mounting/lacking holes, what's the best way to measure my A stamp chassis for the Stealth mounting holes?
Motor plate was easy -- turn last screw in until is leaves a mark.
Tranny drill guide.GodSpeed wrote:Well, I think you're probably right about that.
http://www.ebay.com/itm/CW-060-Associated-RC-10-RC10-STEALTH-Drill-Guide-Gold-Pan-Vintage-Carbon-Fiber-/171542365566?pt=LH_DefaultDomain_0&hash=item27f0b8c57e
Lynn
- GodSpeed
Thanks, but I didn't want to spend $10+ for a 2 second job.Twin Detonator wrote:Tranny drill guide.
Lynn
Thankfully I was helped out by teman here --
http://www.rc10talk.com/viewtopic.php?f=82&t=23763
FYI, there is a guy that is making a replacement Idled gear for the new "China" stealth transmissions. The gears are aluminum and worked great in the tranny. It's a lot smoother, almost as good as my 20 year Stealth (go figure). Here is the link for the Ebay action.
http://www.ebay.com/itm/191354255401?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
- 1901 Views
Last post by badhoopty
- 1251 Views
Last post by longboardnj
- 24 Replies
- 4626 Views
Last post by mrlexan
- 1535 Views
Last post by tiger1
- 1479 Views
Last post by burnsmonkey
- 25 Replies
- 2976 Views
Last post by chophead69
- 20 Replies
- 2984 Views
Last post by dirk_411
- 685 Views
Last post by Bormac
Users browsing this forum: Google Adsense [Bot],
morrisey0,
pma1123,
timjz and 6 guests
