I would love to find one too. My step son and I are about to embark on a 6 gear rebuild and upgrade.
Would also like to see how FordPSD did on that rebuild, I think its been more than 10 days LOL
KO
good Idea...and thanx for volunteering SnoopMax And I'll need your address so I can send you one to rebuild for the video
You already have my address mate
Okay, a little clarity hit. With the new outer bearing, you now have three bearings trying to center the outdrive, and all of them working perfectly together isn't going to happen. So the non-flanged bearing is removed to make it a simpler two bearing system.
This is the method that I use. I actually have a stash of worn 3/16 bearings just for this (to cut the inner race from).GoMachV wrote: ↑Fri Sep 02, 2022 3:34 pm One thing I haven’t tried yet but in my head would work is to remove the outer portion of the unflanged bearing leaving just the inner race. Reassemble using the outdrive screw and that inner race as a spacer. If it holds in place like original (but obviously will now wobble around until the outdrive bearing is installed) then you are golden. The load will still be on the inner bearing like stock, vs on the outdrive bearing using the brass tubing
Going to run with this and see how it works out.GoMachV wrote: ↑Fri Sep 02, 2022 3:34 pm One thing I haven’t tried yet but in my head would work is to remove the outer portion of the unflanged bearing leaving just the inner race. Reassemble using the outdrive screw and that inner race as a spacer. If it holds in place like original (but obviously will now wobble around until the outdrive bearing is installed) then you are golden. The load will still be on the inner bearing like stock, vs on the outdrive bearing using the brass tubing
Users browsing this forum: Google Adsense [Bot] and 17 guests
