RC10 - A Stamp Rebuild - Chipped Idler Gear
- GreenBar0n
- Has thanked: 578 times
- Been thanked: 262 times
Recently received this RC10 from ebay. Got it torn down and cleaned.
One of the idler gears, ASC#6613, has a couple chips out of the teeth.
Is there anyone making those for sale?
- 1300GT
- Has thanked: 331 times
- Been thanked: 272 times
Re: RC10 - A Stamp Rebuild - Chipped Idler Gear
RW racing had these. They're out of stock at the moment.
https://rwracing.co.uk/shop/ols/products/associated-rc10-steel-idler-gears
Chris.
Toys.............they are!
- Frankentruck
- Has thanked: 1589 times
- Been thanked: 1770 times
What the heck?!? Where are the integral steel gears on the outdrives? That doesn't look right.
<edit> Oops, optical illusion from the camera perspective. Nevermind.
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
- With the release of the CC and 40th anniversary cars, there's a chance that AE might release a batch of new ones.
- Same as above, you can look on Ebay for guys parting out new cars.
- You can still find new original gears on Ebay from time to time. Expect them to be pricey. The newer black ones are stronger than the white ones.
- There are 3D printed ones available. My LHS owner said that he has installed a couple sets and that they seem okay. I wouldn't expect them to be as strong as originals.
- You can get some old (worn) outdrives and cut the dogbone cups off. Not my personal choice, as I like the idea of having the idle gears as a week point.
- GreenBar0n
Thanks for the link, I was reading up on the steel gears, and the deburring necessary.1300GT wrote: ↑Sun May 05, 2024 3:30 am RW racing had these. They're out of stock at the moment.
I was trying to get the chipped tooth angle in the picture, the camera flash made it look weird too.Frankentruck wrote: ↑Sun May 05, 2024 6:57 am What the heck?!? Where are the integral steel gears on the outdrives? That doesn't look right.
Much thanks for the options available in 2024! Of all of those, the black Delrin gears sound like the ideal choice.juicedcoupe wrote: ↑Sun May 05, 2024 8:54 am - With the release of the CC and 40th anniversary cars, there's a chance that AE might release a batch of new ones.
@Dangeruss PM'd a shop to me that had the ASC6614 Delrin black gears in stock, for $32 total, it will give me peace of mind knowing it's as good as it gets for a 6-gear.
Thanks again guys, I'll get back to this project when the gears arrive.
- GreenBar0n
Should I put bearings in this kit, or are there any other improvements I could make in the gear box while it's open?
- MarkyDents
- Has thanked: 1361 times
- Been thanked: 511 times
Hey Cru ! Go balls out
- Has thanked: 1013 times
- Been thanked: 472 times
The newer editions of the gears are beige.
That was for the 2013 as well as the cc release.
Does anyone know if they are sturdier than the original gears?
- GreenBar0n
Losi/RC10, wild. Thanks for that!MarkyDents wrote: ↑Sun May 05, 2024 2:50 pm Here’s a fun read.
https://rc10talk.com/viewtopic.php?t=47922
Enjoy.
Would also be curious to know the answer to this.
- GreenBar0n
Having a difficult time figuring out the spur and pinion on this. This is the way I received this car:
The black spur gear in the picture, has the slipper adjustment spring and nut, and the metal clutch discs and plates on either side, but there were no diff balls in the spur gear. Was that supposed to work correctly? This is what I found when I pulled the slipper apart.
The kit included the stock spur/pinion, and bunch of diff balls.
Is there any benefit to the black gear, with, or without the diff balls?
Thanks.
Thanks.
- MarkyDents
No benefit, acts like no diff.
You’ve got everything you need there to make it functional as a diff again.
- XLR8
- Has thanked: 1237 times
- Been thanked: 890 times
The RC10 6 gear didn't include a slipper clutch. Many folks these days mistake the diff for a slipper - like those on the Stealth tranny.
Looks like you have 64dp spur and pinion.
That's a really nice clean survivor. You're lucky to find it.
- juicedcoupe
I wouldn't put a 64 pitch gear on a 6 gear transmission. The spur wobble will likely trash it.
- GreenBar0n
Just to make sure I understand you guys, I should be using the black spur, and I should put the diff balls in, that would be the best I can do with what I've got here?
What's the most ideal setup, even if I have to purchase parts?
First 6-gear I have had, my other (3) are Stealth.
Thanks, guys!
Thanks, guys!
- Frankentruck
64 pitch gears are good for clean carpet / on road driving, but are less durable for any rough surface driving. Whichever spur you choose, put diff balls in it.
- 1238 Views
Last post by 85Edinger
- 1250 Views
Last post by superfly
- 1029 Views
- 1135 Views
Last post by templeofspeed
- 654 Views
Last post by fr3ak317
- 152 Views
Last post by JosephS
- 1066 Views
Last post by SteveK
- 726 Views
Last post by adam lancia
Users browsing this forum: Amazon [Bot] and 41 guests
