my RC tires leave black marks everywhere any solution?
- TokyoProf
- Has thanked: 476 times
- Been thanked: 343 times
I have an RC10B2 (shelf display) that leave black tire marks everywhere. The pins on the tires are like pencils. These are the only tires that do this.
My preference is to keep the glued vintage tires on the rims. Is there a spray or sealant you would recommend?
- Has thanked: 2287 times
- Been thanked: 1994 times
Re: my RC tires leave black marks everywhere any solution?
Hope this doesn't sound too basic but you should always store the car with the wheels off the shelf to stop flat spots . Other than that a lot of people use silicone to give the tires some shine , it might help with the marks .TokyoProf wrote: ↑Sun Nov 12, 2023 9:19 pm I have an RC10B2 (shelf display) that leave black tire marks everywhere. The pins on the tires are like pencils. These are the only tires that do this.
- TRX-1-3
- Has thanked: 1399 times
- Been thanked: 764 times
The tires sound like they might be natural rubber. I can't remember the actual component.....but when I did fleet maintenance, there was some damn rubber component/part that I.......bingo, it was air intake pipes/boots. They would get kinda chalky from time-to-time...
Long story short, I would scrub the p*ss out of them with warm soapy water, until I got down to a smoother, more lustery surface finish. There would be tiny black particles, like ash floating on water, in the shop sink after rinsing. Then I'd give them a smudge test with my thumb. If they still imparted the black stuff, I'd scrub them again, etc. until they were "clean". I wouldn't scrub them violently. Just happy little circles with light to moderate pressure. Rinse and repeat until desired results were achieved.
Now, I wasn't scrubbing vintage R/C tires, but that might be worth a try. Assuming they are still pliable. Then apply a light silicone based product to them. Of course "test in a small inconspicuous area" first.
Ah. Just read the "keep them on the rim" part. Still possible, just need to get your soapy water into more of a lather, then some precision trickle rinsing.
Oh yeah, I'd be hesitant to hit them with a sealant and I would think that siliconing them without removing the chalkiness would just make the pins act like grease pencils.
I'm crazy enough...have you examined the tires with a magnifying glass? One of those tiny ones, like a jeweler's loupe. I would take a look at the base of the pins for cracks first. Bend them around with a toothpick and observe the base. My concern would be scrubbing the pins off the face. Maybe I'm over-thinking it.
I'd go with a "GUM" or "ORAL-B" soft to medium bristle and Palmolive because it softens hands while you do the dishes.
- Dangeruss
- Has thanked: 148 times
- Been thanked: 553 times
Just the rubber oxidizing, even silicone oxidizes. Any automotive tire shine should work. I prefer Mothers 16915 Speed Tire Shine. Rubbed in and wiped off tires/parts look new rather than just shiny. Or you could encapsulate the tire by spraying it with clear plasti-dip or similar, which is removeable. All the sudden wondering about automotive spray wax... or even Endust... hmmm....
- Lowgear
- Has thanked: 78 times
- Been thanked: 596 times
It seems like the preferred stuff to coat rubber R/C tires with is 303 Aerospace protectant. You have to be careful with what you use as some rubber protection products will actually cause the rubber to degrade.
Some good info here: https://www.rc10talk.com/viewtopic.php?t=17978
- Been thanked: 288 times
Here's what I did to store my finished cars; cheap, looks great and keeps those tires off the ground...a bunch of dollar-store clear plastic containers, with strips of foam tape stuck on the tops. I second the suggestion to use 303 Aerospace Protectant on any plastic, vinyl and rubber.
https://www.rc10talk.com/viewtopic.php?f=39&t=19521&hilit=stand&start=62
- 42 Replies
- 2148 Views
Last post by SnoopMaxx
- 1065 Views
Last post by Synergy
- 733 Views
Last post by shodog
- 1995 Views
Last post by SMOKE-DOG
- 1323 Views
Last post by R Cane
- 489 Views
Last post by illshou
- 774 Views
Last post by RustyBall
- 3910 Views
Last post by RC10th
Users browsing this forum: No registered users and 15 guests
