Vintage AE's A&L Trailing Arm RC10
- vintage AE
- Has thanked: 29 times
- Been thanked: 35 times
I feel like noobe all over again. I started this build years ago when painting an extra body I had lying around. After sitting on it awhile I've finally decided to pull the trigger on the A&L chassis kit. I opted for the 4 hole front tower and fiberglass chassis.
There will be some waiting on select parts, so this will be built on pace with someone Jason's builds... unless he has gotten quicker at his builds over the couple of decades
Here's the starter pic.
- Frankentruck
- Has thanked: 1589 times
- Been thanked: 1770 times
Re: Vintage AE's A&L Trailing Arm RC10
That looks like it's going to be a really cool build. Such a nice group of parts gathered together there.
- MarkyDents
- Has thanked: 1361 times
- Been thanked: 511 times
Cool build, the black trans…. Lethal Weapon ?
Hey Cru ! Go balls out
- vintage AE
Yes sir. It doesn't look like it will bolt up to the A&L chassis though
- vintage AE
I forgot just how much fun cleaning white RC10 parts were, said nobody ever lol.
I keep telling her that a good pipe cleaner and some bleach goes a long way!
- Has thanked: 822 times
- Been thanked: 2418 times
Chassis would need to have two holes drilled out, a longer trans brace, and you would need to modify the rear bumper. They trans and the chassis were different eras, and were not really used together. That said I have built quite a few c2 with lethal weapon.
Factory Works website
- vintage AE
I'll be doing this for sure I can't have a new lethal weapon transmission and not install it in this chassis.GoMachV wrote: ↑Sat Jun 25, 2022 10:06 am Chassis would need to have two holes drilled out, a longer trans brace, and you would need to modify the rear bumper. They trans and the chassis were different eras, and were not really used together. That said I have built quite a few c2 with lethal weapon.
It looks like the donor Championship car with the Team car shocks is going to need help with donating parts, the rear bulkhead is cracked around the battery housing.
In comes donor number 2, a RC10 graphite. I feel so reckless tearing into a complete RC10 at least it's for a good cause.
- MarkyDents
It’s all good as long as you put that nice looking graphite back together with the correct pirated pieces when your done
- vintage AE
No fear of that! I even have the first car back together as much as I can. Loose parts and hardware give me anxiety lol, clear space, clear mindMarkyDents wrote: ↑Sat Jun 25, 2022 4:39 pm It’s all good as long as you put that nice looking graphite back together with the correct pirated pieces when your done
It gives me more room to polish my old balls and pins. I even stuck the front axles in the drill and gave them a once over.
Top one is dirty, bottom is cleaned.
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
That's a nice graphite car
- Frankentruck
If you didn't mind it being made of black nylon, I could 3D print you a rear bulkhead. Your RC10 Graphite wouldn't have to get cannibalized for that part.
- vintage AE
That is so tempting! I want as many white parts on this as I can, because fibreglass chassis' look great with white parts and stainless hardware.Frankentruck wrote: ↑Sun Jun 26, 2022 12:11 pm If you didn't mind it being made of black nylon, I could 3D print you a rear bulkhead. Your RC10 Graphite wouldn't have to get cannibalized for that part.
As odd as this is...would you consider blue or red? At least is would jive better with the paint scheme.
Another option would be to buy a white one that would be worth trimming the ballstud tabs off, since they have to be removed anyway. I think I will head to ebay to see what unicorns lay waiting... maybe I find some cheap NIP white long arms too
- Frankentruck
I think all I have is black nylon right now, but I'll double check if I have enough white nylon left. The white can be dyed. I could also eliminate any features you didn't need, like the ball stud mounts.
- vintage AE
Well, I've mod'd the rear bumper and installed the longer trans brace, but have yet to drill the chassisGoMachV wrote: ↑Sat Jun 25, 2022 10:06 am Chassis would need to have two holes drilled out, a longer trans brace, and you would need to modify the rear bumper. They trans and the chassis were different eras, and were not really used together. That said I have built quite a few c2 with lethal weapon.
I have a few unanswered questions... I mean hardware, is the fiberglass plate meant to be the drilling template?
Also, what are the other screws for?
I've temporarily used the graphite car's rear bulkhead to mock things up
- 33 Replies
- 7096 Views
- 789 Views
Last post by THUNDERSTRIKE1
- 3382 Views
Last post by KidAgain
- 986 Views
Last post by carloco8
- 1177 Views
Last post by nvxwax
- 94 Replies
- 9556 Views
Last post by GeneralZod
- 2811 Views
Last post by orangemazda
- 1567 Views
Last post by Zac_F71
Users browsing this forum: Semrush [Bot] and 34 guests
