RC10 Basher CNC
RC10 Basher CNC
Hello friends of the RC10
I'm alway in doubt wether I shoud use my RC10s in bad conditions (dirt, mud, snow, skatepark...). It would be a lot of fun, but it would also be a shame to destroy original parts. So I bought a CNC Machine and I will build some "Basher-RC10"s for my Hobbyroom. Biggest compromise: the chassis. Bending this "pan" is very difficult, so I designed a flat chassis with upper deck. First tries made out of some old aluminium, later maybe anidized, and I will make some of carbon.
Noseplate is milled and then bent. Not so easy ti find the right place to bend it, but the next one will be better. I make cuts, 0.5mm deep with a ball end mill to define the place where it bends.
RC10 collection in Switzerland: Original, Classic (ReRe), "Plastic" (homemade milled white cahssis), CE, Graphite-Andys, TeamCar, WorldsCar, WorldsCar ReRe, "CouldHaveBeen" (homemade similar to "RPM"), B3, 3x B4, 2x B5
- Has thanked: 2287 times
- Been thanked: 1994 times
Re: RC10 Basher CNC
Wish I had a CNC mill to play with , great project
Re: RC10 Basher CNC
- RC10th
- Has thanked: 40 times
- Been thanked: 1016 times
Re: RC10 Basher CNC
Yes of course, with some kind of small upper deck. Just have to draw and mill it.
Re: RC10 Basher CNC
This is how it looks right now:
Still some work to do. Sand the edges, brush, anodize. And don't laugh at the VCFS ("various chassis flex system TM"), also called "cable ties" , which fix the nose brace upper deck to the nose plate. They will be replaced by screwed parts.
Re: RC10 Basher CNC
This is how it looks now. I made the parts whick connect the nose brace upper deck to the noseplate and the upper deck to the rear bulkhead.
As you can see it is getting serious here. Or series? If i have the machine ready I always make two, three or four, when the machine is ready it is done quickly.
I'm happy with the form of the parts, how they fit together. But as you can see, the surface is away from perfection. In Polyamide you need very very sharp tools and it is not easy to adjust spindle rpm an feed rate to get a smooth surface without burrs. But it's OK, I'm learning...
Stiffness of the chassis assembly completed is very similar to the tube version, so I hope it will handle well on the track.
And I made a new steering bellcrank with an aluminium rack.
- 1454 Views
Last post by adam lancia
- 1449 Views
Last post by fredswain
- 1497 Views
Last post by PBR Allstar
- 579 Views
Last post by Brandon G
- 276 Views
- 1704 Views
Last post by Seabass
- 2182 Views
Last post by joey_zrl
- 781 Views
Last post by Tadracket
Users browsing this forum: No registered users and 41 guests
