RPM “ 91 Worlds “ with Composite Craft chassis
- MarkyDents
- Has thanked: 1361 times
- Been thanked: 511 times
Admittedly going to be a long while until I get into this one, still working out exactly what I want to do with it.
For those that may not be familiar with the RPM 91 Worlds parts
Hey Cru ! Go balls out
- jcwrks
- Has thanked: 121 times
- Been thanked: 259 times
Re: 91 RPM Worlds with Composite Craft chassis
That's a nice canvas to work with. I'd start by dying all of the nylon and towers black.
The official TX SKUNK
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
Nice! That’s a unicorn buggy. A lot parts from different manufacturers has to come together.
- MarkyDents
Thank you gentlemen, I’m definitely doing some careful planning. Make sure I do it justice.
- MarkyDents
Re: RPM “ 91 Worlds “ with Composite Craft chassis
Did a quick brush off just to inspect everything, found a couple nice pieces and some I need to question.
The rear bulkhead has been cut out and sits down around the lower chassis, Is this normal ? Also I’ve decided I like the rpm parts in blue, pretty even dye job and in good shape so they will stay this way.
After making the front springs go away for good I can see the front rpm cups, eyelets, spring retainers, and adjustment clips are present.
Couple other rpm goodies. The rear bulkhead has been cut out and sits down around the lower chassis, Is this normal ? Also I’ve decided I like the rpm parts in blue, pretty even dye job and in good shape so they will stay this way.
The purple and pink definitely gives it that 80s/90s look and feel when neon/fluorescent colors were popular.
- Has thanked: 10 times
- Been thanked: 447 times
Those yellow front springs are correct for the rpm front end. They are the 'medium' set from rpm and what they recommended for initial setup.
- MarkyDents
Oh really, I honestly thought they were Losi springs.
- Has thanked: 28 times
- Been thanked: 957 times
Yeah, they had yellow (soft) and silver (medium).
- MarkyDents
Yes they did fit them well. I mean it’s not that I threw them out I just really don’t want yellow springs on it.
- MarkyDents
As for the turnbuckles, Tecnacraft ?
Think they are long enough that I can ditch the Losi ballcups for more appropriate RPM ballcups ?
The Losi cups use the same ball size correct ?
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Yes, same ball size.MarkyDents wrote: ↑Sun Sep 05, 2021 12:38 pm As for the turnbuckles, Tecnacraft ?
And RPM cups are made in two different lengths.
There are some comparisons here.
https://www.rc10talk.com/viewtopic.php?f=38&t=46277
- MarkyDents
Awesome thank youjuicedcoupe wrote: ↑Sun Sep 05, 2021 12:56 pmYes, same ball size.MarkyDents wrote: ↑Sun Sep 05, 2021 12:38 pm As for the turnbuckles, Tecnacraft ?
- MarkyDents
They may not be perfect specimens but since I know it’s been mentioned before and it is something of a rare opportunity to do so, I figured I’d take some side by side photos to display their similarities and differences shape wise.
- 63 Replies
- 11422 Views
Last post by Peakey
- 865 Views
- 47 Replies
- 2418 Views
Last post by jcwrks
- 2526 Views
Last post by asashaw
- 1512 Views
- 632 Views
- 2044 Views
Last post by Showcase1186
- 3454 Views
Last post by Twistedaxle
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 35 guests
