white idler gear
white idler gear
hi guys i did a search but couldnt find much info...
is there any significance to a white idler gear? any info appreciated! thanks.
peace,
gamma
:edit: for a stealth.
peace,
gamma
- JPAE07
Re: white idler gear
Yeah, originally they (the idler gears) were white.
Black was transitioned to as replacements during the Team Car years when thats what color the rest of the parts were.
Associated still has them too.
- Has thanked: 28 times
- Been thanked: 957 times
the white idlers (nylon) were used up until the rc10 graphite came out (89). that's when they switch to the black ones (delrin). they held up much better.
- Been thanked: 12 times
is that for the stealth or 6 gear? didn't they both have black or white idler gears at diferent times?scr8p wrote:the white idlers (nylon) were used up until the rc10 graphite came out (89). that's when they switch to the black ones (delrin). they held up much better.
for the 6 gear.
i don't recall every seeing a white idler for a stealth from associated.
It's more of a tan than a white, but it definately is not black
http://cgi.ebay.com/Team-Associated-Idler-Shaft-Gear-Part-6570_W0QQitemZ260133947979
scr8p wrote:for the 6 gear.
ya, i forgot about those. i have no idea when the started making them in that color. what color were the idlers in the b3/t3 kits? i believe they used the same idler.
the idlers for the b3/t3 had the bearings inside the idler and the shaft was fixed into a hole in the trans case. i never liked that style thats the same way losi xx and newer trannnys are as well.
- Has thanked: 7 times
- Been thanked: 41 times
It's probably cheaper to make a single piece of plastic rather than a 2 part gear with a steel shaft pressed into it.
- 1250 Views
Last post by superfly
- 1136 Views
Last post by templeofspeed
- 654 Views
Last post by fr3ak317
- 829 Views
Last post by joel45acp
- 157 Views
Last post by JosephS
- 1066 Views
Last post by SteveK
- 693 Views
Last post by RC10th
- 886 Views
Last post by 1300GT
