Re-Re vs Vintage
- Been thanked: 18 times
Re-Re vs Vintage
Does anyone know if some of the Re-Re parts are interchangeable with the vintage counterpart. In particular, the "Fighting Buggy" and the "Super Champ", and the vintage and re-re of the Sand Scorcher. Particularly the suspension parts.
- Has thanked: 19 times
- Been thanked: 29 times
Re: Re-Re vs Vintage
Most of the parts are interchangeable....
- Pepito
- Has thanked: 4 times
There are a few parts that have changed color and/or have been "upgraded" that make them less desirable to a collector.
But if you are only to get it running again to bash around, re-re parts are a great source for replacement parts.
If there is a particular part you are questioning in the suspension or any other area of the RCs, let me know.
Living life a 1/4 mile at a time.
I am not as interested in the "collector" aspect for myself. I love vintage but like to run them. I run my SWB Wild Willy, and it makes collectors "cringe", but, they were made to run IMHO.. lol.. I used to have a Super Champ back in the 80s, but sold it and miss it. Always loved the SRB cars, and plan to get either a Re-Re Sand Scorcher, or Super Champ again, project or RTR, or even a kit to be built. But if I find an old basket case, I want to know if I can use the Re-Re parts to replace broken parts on an old one. I think it is cool if it is all vintage parts, but if I get it to run with new parts, so be it. I rather run it than it sitting pretty on a shelf.
- Pepito
I believe the Super Champ is a straight run from the original cast with a few exceptions. You should be able to interchange and "upgrade" the original to run re-re parts without issue.Tudorp wrote: ↑Sat Feb 08, 2020 2:08 pm I am not as interested in the "collector" aspect for myself. I love vintage but like to run them. I run my SWB Wild Willy, and it makes collectors "cringe", but, they were made to run IMHO.. lol.. I used to have a Super Champ back in the 80s, but sold it and miss it. Always loved the SRB cars, and plan to get either a Re-Re Sand Scorcher, or Super Champ again, project or RTR, or even a kit to be built. But if I find an old basket case, I want to know if I can use the Re-Re parts to replace broken parts on an old one. I think it is cool if it is all vintage parts, but if I get it to run with new parts, so be it. I rather run it than it sitting pretty on a shelf.
Hope that helps!
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
The front arms are different and use a different ball cup. Those are usually worn on the vintage rides and are not interchangeable with the retention with having to change the arms also
- Pepito
So only the arms are different or is the whole front end slightly different?
Sounds like the suspension may be different which I hadn't noticed (but then again, I haven't paid much attention to the re-re).
Thanks for the heads up!
- Has thanked: 2287 times
- Been thanked: 1994 times
I've got a little more information on the front suspension differences , the modern front arms are not only thicker and less pleasant looking , they are also angled differently , the older ones angle out from the chassis at a greater angle , I found this out after braking an original upper arm and while I'm waiting to find a replacement I ordered a modern pair of top arms and when I fitted them it gave the wheel negative camber , also as mentioned earlier the ball plate and ball stud are different , you could fit vintage ball plates on new arms but because the modern ones use a bigger ball stud the ball plate is also bigger and needs a bigger hole at the centre , the tear drop shape and screw hole are identical .
The lower angle on the front arms would reduce the front track so they have elongated the tubes between the suspension/shock mounts to increase the track again , I don't know if the screw hole locations for mounting the front suspension to the chassis is the same ....
- 72 Replies
- 10061 Views
Last post by ron
- 128 Replies
- 39832 Views
Last post by THEYTOOKMYTHUMB
- 74 Replies
- 6952 Views
Last post by 1911Colt
- 1984 Views
Last post by justinspeed79
- 2365 Views
Last post by paul
- 921 Views
Last post by discgolfer72
- 1954 Views
Last post by zjrog
- 849 Views
Last post by Bent
