Castor block choices
- KidAgain
- Has thanked: 288 times
- Been thanked: 198 times
DS for drag racing only what would you guys run up front 5,10,15,20,25 or 30*, I got some 5’s and it pitches the castor blocks something fierce towards the (correction) FRONT of the car not sure this is what I want?
Any recommendations would be extremely helpful.
Thanks
Jake.
Thanks
Jake.
Gone: RC10, Jrx-2 and Jrx-t
Current: 3 SC10 first gens, 3 SC10 Street Outlaw's, 12 RC10 DS’s, Carbon RC10T, RC10LSS,RC10L, RC10 Graphite,RC10 B44
- ChisaiKuso
- Has thanked: 4 times
- Been thanked: 27 times
Re: Castor block choices
There are no turns in drag racing, so it really does not matter too much what you use. Any steering input you make during a race should be absolutely minimal.
EDIT: If you are interested in how 1:1 scale drag racers setup their cars, then take a look at this: https://www.onallcylinders.com/2015/01/15/steering-straight-inside-story-wheel-alignments/.
Something clever goes here...
- RC10th
- Has thanked: 40 times
- Been thanked: 1017 times
Run as much caster as possible to increase straight line stability.
- Has thanked: 10 times
- Been thanked: 447 times
30 degree blocks will give you the most srock caster, at 8 degrees to match the ds noseplate. The 30 degree blocks have no offset. So they will be any angle a kickup would be.
From there, to get any more caster, you would have to flip others left to right and trim the rib off to get the travel you need. With a dragster, it won't need much steering angle anyway.
Run as much caster as you can. You could take your 5's, trim them and flip them, you will end up with 33 degrees negative caster.
- KidAgain
Can you show me where to trim, are you talking about the steering stops molded on steering arms or modify the castor block itself?jwscab wrote: ↑Wed Apr 24, 2019 7:48 am 30 degree blocks will give you the most srock caster, at 8 degrees to match the ds noseplate. The 30 degree blocks have no offset. So they will be any angle a kickup would be.
Positive castor is when the castor blocks are tilted towards the REAR of the car not the front correct?
whoops. yes, i meant positive caster, with the top of the spindle leaning behind the wheel as you move forward.
yes, you have to trim the caster block, the rib and possibly some of the back side. though, as a dragster, you might be OK as is with just a few degrees of steering angle. you likely won't have much suspension travel, so any other trimming might be unnecessary, but can include trimming arms or more of the side of the caster block. also be sure to adjust your steering trim and travel if possible so everything works without binding.
- Attachments
- caster block trim.jpg (22.62 KiB) Viewed 2126 times
- KidAgain
5* castor blocks flipped and modified after a few answered questions this is what we got for mock up
Let’s see how it works out for straight line runs.
- ChisaiKuso
I am anxious to see how this build turns out. Please keep the updates coming.
- 1406 Views
Last post by Orange
- 988 Views
Last post by snowfox
- 517 Views
Last post by Jay Dub
- 2057 Views
Last post by Sparbolt
- 1753 Views
Last post by kaiser
- 670 Views
Last post by shredderboy
- 1688 Views
Last post by TRX-1-3
- 1782 Views
Last post by Welshy40
