The Giant RPM part number thread
- lowrydesign
- Has thanked: 11 times
- Been thanked: 17 times
This thread will be for all of you RPM junkies like myself.
My goal here is to list every EARLY RPM RC10 part made( 4 DIGIT numbers only), with the part number and tag description in numerical order.
This will be a working living post that I'd like to keep updating with part numbers that I do not have, if you have a part # not listed or my verbiage is incorrect, please post with the part # and the words listed exactly as the tag says and I'll add it to the list, thank you and enjoy!
#7002 RC10 Bellcrank Set
#7005 RC10 Front Spindle Blocks Inline
#7007 RC10 Rear Carriers (stock no toe)
#7008 RC10 93t. Gear Cover (Molded Nylon)
#7011 RC-10 Molded Gear Cover (Dyeable)
#7012 Molded Gear Cover (Stealth w/Hydra)
#7013 RC10 Front Oval Bumper Body Support
#7014 RC10T Body Post Set (4)
#7016 RC10 Rear Oval Bumper Body Support (Stealth)
#7017 Steering Enhancement Kit (RPM "Worlds" front end) <-- Must use Assoc. #6220 alum. axles
#7018 RC10 Delrin Shock Pivots (8)
#7019 Steering Enhancement Kit
#7020 1PC. FRT SUSPENSION MOUNT RC-10
#7023 .250 x .500 Bearings & Carriers (for RC10GT & RC10T trucks)
#7024 Replacement Bearing Set (4)
#7026 DRIVE-TRAIN POWER KIT RC10T anti-telescope Rear Carriers No Toe 3 deg. /side toe in blocks
#7027 Replacement Carriers for .250 x .500 Bearings (without bearings)
#7028 Oversize Bearings for 3/16" Axles (4) Assoc. Trucks. <-- Must use #7027 carriers
#7030 RC10T Rear Arms (White)
#7031 Up-Travel Limiter Clips for Shocks (Assoc.-Losi-Traxxas-Kyosho)
#7034 RC10 Team Car Rear Bulkhead
#7035 Rear Bulkhead RC10GT
#7038 RC10T Rear Bulkhead
#7040 RC10t Front Suspension Arms (White)
#7041 RC10 Shorty Bumper-Skid Plate
#7044 RC10 Front Arm kit (team car)
#7047 Stealth Transmission Brace (RC10 & RC10T)
#7050 RC-10 Battery Box / Losi JRX2 Battery box
#7052 RC10T 3Deg. Rear Mounts
#7053 RC10GT 3º Rear Mounts
#7054 RC-10 Rear Arms
#7060 Front Wide Arms TRUCK RC10
#7062 RC10T2 3deg. Rear Mounts
#7065 RC-10 Low Profile Rear Carriers
#7071 Mini Bumper-Skid Plate
#7072 Mini Front Bumper 10T T2 GT
#7077 "91 WORLDS" RC10 Team Car Front End Kit
#7078 Shock Body & Cap Wrench (for Associated shocks)
#7079 Team Car Rear End Kit (Narrow Chassis Long Arms)
#7082 Nylon Nuts 6-32
#7089 One Piece Center Link (bellcrank) Assoc. cars & trucks)
#7092 RC10 Rear Suspension Blocks ( 3° Toe-in each side)
#7095 RC-10 Wide Rear TRUCK Arms & Carriers
#7338 Heavy Duty Rod Ends (12) White Losi, Assoc. (dyeable) ---- holy grail.
#7339 Long Shank Rod Ends (12) Losi, Assoc. <-- Black
#8001 "Worlds" Special Arms (white)
#8002 RC-10 Ball Bearing Bellcranks
#8003 Worlds Front Shock Tower
#8009 "World's" Spring & Ball Cups (2 ea.)
#8012 RC-10T Ball Bearing Bellcranks
#8015 Nose Brace Tubes (short and long chassis)
#8017 Replacement Rear Arms (R.P.M. Narrow Chassis)
#8018 RC10T2 Gear Cover (Slipper)
#8019 Replacement Rear Carriers (R.P.M. Narrow Chassis)
#8021 Replacement Rear Mounts (1.5 & 3 deg.) (R.P.M. Narrow Chassis)
#8022 Gear Cover for RC10T2 (Hydra)
#8023 Rear Shock Tower (Molded Car Chassis)
#8027 "Worlds" Med. front springs (silver)
#8028 RC10 B2 Gear Cover
#8029 "World's" Soft Front Springs <-- Yellow
#8030 Snap-Tite Body Savers for Assoc. Trucks & "B2" (small posts) <-- Black
#8031 Snap-Tite Body Savers (dyeable) for Assoc. Trucks & "B2" (small posts) <-- White
#8032 Gear Cover "B2" (Hydra)
#8033 Snap-Tight Body Savers
#8036 Ultra Chassis Front Bulkhead
#8044 Front Arms for "B3"
#8045 "B2" Short Front Arms (1/4 in.) Pavement, Carpet and Oval
#8047 B2 Rear Bumper/Motor Protector
#8050 Module Removal Clip for Airtronics CS2P & XL2P
#8051 RC10 B2 Mini Bumper
#8054 Adjustable Body Mounts for 10T, T2, GT
#8055 2.65 STEALTH conversion for RC10T (with slipper top shaft)
#8056 REPLACEMENT 2.65 Top Shaft for Slipper
#8057 2.65 STEALTH Conversion for RC10T (with Hydra top shaft)
#8058 REPLACEMENT 2.65 Top Shaft for HYDRA
#8059 1.96 STEALTH Tranny Conversion (for OVAL RC10 & RC10T)
#8060 REPLACEMENT 1.96 Top Shaft Only
#8071 Gold Wheel Nuts & Knock-Offs for Assoc. "DS" 4ea.
#8072 Chrome Wheel Nuts & Knock-Offs for Assoc. "DS" 4ea.
#8080 ULTRA MOLDED CHASSIS Narrow RC10 Edition (Entire kit with arms)
#8090 RC10 T ULTRA MOLDED CHASSIS
#8093 "10GT" Zero Deg. Rear Toe-in Blocks
#8118 B3 & T3 Hi-Impact Spindle Blocks
#8119 "Fatboy" Gold Sedan Pipe
- jcwrks
- Has thanked: 121 times
- Been thanked: 259 times
Re: The Giant RPM part number thread
Thanks for composing this list.
I believe #7335 should be 7338 since I have a nip set of them.
#8029 "World's" Soft Front Springs <-- yes they are yellow
The official TX SKUNK
- Has thanked: 51 times
- Been thanked: 45 times
Hi, curious, where did you find this part number?lowrydesign wrote: ↑Fri Jan 12, 2018 10:54 pm This thread will be for all of you RPM junkies like myself.
- Has thanked: 822 times
- Been thanked: 2418 times
Photo credit to Aaron
Factory Works website
That is pretty cool! I was racing the molded chassis and developed that kit. The chassis kit had been out for a while but sales had slowed so we never put it in the catalog and subsequently it was typically not sold to or sent to distributors. The enhancement kit was usually sent out if someone contacted us to ask for set up tips or to RPM racers actively running the molded chassis.
- lowrydesign
This is pretty cool, care to share any more on the life of the ultra cars?RPMfieldtester wrote: ↑Fri Mar 05, 2021 9:46 am That is pretty cool! I was racing the molded chassis and developed that kit. The chassis kit had been out for a while but sales had slowed so we never put it in the catalog and subsequently it was typically not sold to or sent to distributors. The enhancement kit was usually sent out if someone contacted us to ask for set up tips or to RPM racers actively running the molded chassis.
sadly, my memory of the details is not what it used to be and I didn't document what I did...I started working at RPM shortly after the car kit came out. In the std "worlds" config, the front end had too much droop and tire scrub. It would work ok on loose fluffy tracks but gave up a lot and pushed on the hardpack tracks. I made a new shock tower to angle the shocks in a little more, limited the down travel on the shocks and it worked better but it still needed a little more...by this time, the T was out and we were racing it all over. Some RPM drivers liked it in the "factory" assoc setup (rear arms swept forward, short front steer arms and steering from the RC10). That is when I made the enhancement kit first for the T and the geometry trickled down to the car. The assoc setup had much more and quicker low speed steering but gave up some traction, the RPM set up was easier to drive at race speed, more consistent and had more traction with the arms in line.
It was fun working with Richard, I would come to him with specific ideas or he would go to races with me and see what we were dealing with and he would start machining...sometimes he would make hand machined parts for me to test, (I have previously posted pictures of a few prototypes), other times we would go straight to production and before I knew it, we were molding parts and tools...
- Has thanked: 946 times
- Been thanked: 563 times
Here are some more for the list...
7091 Metric Wheel Nut Wrench 5.5 & 7mm
7099 Precision Camber Gauge
Losi JRX2 - LXT parts..
7300 JRX2 Heavy duty Rear Links
7301 JRX2 Rear Toe-in Links .050”
7302 JRXT Heavy Duty Bellcrank Set
7305 JRXT Rear Links Wide
7306 JRXT Rear Toe-In Links .050” - Wide
7307 Gear Cover Losi Slipper & Hydra
7308 JRXT 93t Gear Cover - black
7310 JRX2 Spindle Blocks Heavy Duty
7311 Losi Molded Gear Cover (Dyeable)
7313 Front Oval Bumper-Body Support Losi
7315 JRX2 Heavy Duty Side Bulkheads
7318 Delrin .250” pivot balls
7320 JRX2 Bumper
7321 Losi Outdrives ("U" only)
7325 JRXT Side Bulkheads Wide
7327 Losi Anti-Squat Bars (#1 & 2)
7328 Losi Top Shock Pivots
7330 Jrx2 Front Bulkhead (+10 deg caster)
7340 JRX2 Front Arms
7345 JRX2 Rear Arm Conversion Kit
7350 JRXT Wide Front Arms
7355 JRXT Wide Rear Arms
7365 ESC Tray (Losi Junior Chassis)
7367 Zero Toe-In Bars Losi (oval/carpet)
7370 LXT Front Arms
7375 Losi Swept Front Arms
7378 Losi Front Bulkhead
7380 Losi Tall Upper Chassis Brace
7385 Losi Heavy Duty Front Carriers
7320 JRX2 Bumper
7370 LXT Front Arms
-Brad
- mytimac
- Business Member
- Has thanked: 7 times
- Been thanked: 54 times
Some more part numbers going through my info I have.
Yes, 8028 is a RC10 B2 Gear Cover
Also FYI these are out of order.
- lowrydesign
- 961 Views
Last post by surgetek
- 1048 Views
- 405 Views
Last post by a01butal
- 1315 Views
Last post by liquorboxracing
- 525 Views
Last post by PBR Allstar
- 625 Views
Last post by crusaderlyf
- 732 Views
Last post by kink
- 818 Views
Last post by clm
