I'm gonna guess this isn't gonna work?????
- abailey21
So I got one of those flashy sparkly Flashback RC towers which uses the inner hole only on the front tower.... Guess my RPM ballcups won't work?
I really despise the "green" stock ones
#whiteballcupsmatter
- klavy69
- Moderator
- Has thanked: 561 times
- Been thanked: 265 times
Re: I'm gonna guess this isn't gonna work?????
no matter what tower you use thats gonna happen with rpm ballcups in that position. There is multiple threads around telling a fix of it. Shorter ball studs help, some go with 2 stock white ballcups in that spot. Some do both. I'm sure if you can't find the thread that was here recently about it someone will chime in with part numbers and such...
- abailey21
Thanks for the quick words, I was thinking of just swapping those cups out. I originally had them in an outer hole on an RC Carbon tower and they cleared fine. Inner hole....not so much
- klavy69
- Moderator
but that tower looks damn good though doesn't it
- abailey21
It does, I was pretty bummed I actually finished wiring this car before I left the country for work. I got home and went to install them and I'm like crap...I wired the car already. So i'm holding on the rear right now
- Has thanked: 28 times
- Been thanked: 957 times
Yeah, gotta run the short ball studs with the rpm cups. One on each side of the tower and one on each outer bellcrank.
Yes, but the ones I've got before weren't aluminum (at least tower says they're aluminum). Not totally sure those actually are though, unless they changed something the last few years. Mine weren't.
- Been thanked: 4 times
Hey OP, I think you want P/N 3981? I've used those in that location and they're steel.
- Been thanked: 7 times
#9145 are short on the ball end but have the longer thread to have enough meat on the other side of the shock tower for a nut.
- 1438 Views
- 21 Replies
- 2362 Views
Last post by GeneralZod
- 29 Replies
- 8232 Views
Last post by RC10resto
- 19 Replies
- 1082 Views
- 731 Views
Last post by THEYTOOKMYTHUMB
- 23 Replies
- 1064 Views
Last post by purpletimbo
- 1799 Views
Last post by 8rad
- 663 Views
Last post by LowClassCC
