Andy's Pro Race restoration with Pro-Steer rack and pinion
Found this on eBay a little while back and hopefully I can get it back to the way it once was in it former glory
- Has thanked: 14 times
- Been thanked: 57 times
Re: Andy's Pro Race restoration
Very cool!
I went a slightly different direction with mine. More if a WOIN build. http://www.rc10talk.com/viewtopic.php?f=36&t=36923&start=15
I kinda wish I would have went with some trailing arms though.
I look forward to seeing your build!
- aeiou
That should clean up nicely. The steering and axles are a cool twist on this setup.
looks good man! I debated pretty heavily on making mine a 10t but I just couldn't let those trailing arms go to wasteorangemazda wrote:Very cool!
Got it all stripped down and cleaned. I washed everything b with super clean and gave the chassis a rub down with some olive oil
Next is to give those wheels a bit of a cleaning. They have quite a bit of scuffs and a ton of excess glue on them, I'm going to try the acetone approach and see what happens
Thanks! So far so good, I wish I knew what axles they were so I could find some replacement shafts.aeiou wrote:That should clean up nicely. The steering and axles are a cool twist on this setup.
The wheels are cleaning up really well. A bit of sand paper and A LOT of elbow grease goes along way
Nice!
If you want to get rid of that pesky MIP trans, I'll get rid of it for you!
You can pull it from my cold stiff fingers when I'm dead lolorangemazda wrote:Nice!
Here is a nice little added touch my friend polished up holding off on the rears for now to let my fingers heal a bit from sanding and polishing the front rims
- Asso_man!
- Has thanked: 40 times
- Been thanked: 70 times
Nice chassis there. Rear axles are Raborn, good luck finding spares...Twistedaxle wrote:Thanks! So far so good, I wish I knew what axles they were so I could find some replacement shafts.aeiou wrote:That should clean up nicely. The steering and axles are a cool twist on this setup.
Come and visit the stable
- LurkingCAT
- Has thanked: 102 times
- Been thanked: 154 times
This cleans up nicely.
Me too - really liked the SP1, slider axles, trailing arm and steering rack combo! And a pro racer... such a desirable car
- aeiou
That did clean up nice - looks great! I used the MIP trans on my Andy's builds as well. I think it's the perfect match for the Pro Race setup.
- 317 Views
Last post by jcwrks
- 2211 Views
Last post by Asso_man!
- 515 Views
Last post by Lavigna
- 1140 Views
Last post by integra22t
- 29 Replies
- 3343 Views
- 986 Views
Last post by fredswain
- 1307 Views
Last post by USA-1
- 5369 Views
Last post by jcwrks
Users browsing this forum: No registered users and 42 guests
