I was bored the other day so I decided to take a few pics of the different front axles that can be fitted to the front of an RC10 to vary the width.
Top to bottom are:
7222 wide GT axle - what B4 wheels generally call for
7459 inline T4 axle - a tad wider than stock, needs to be drilled out to 1/8" to use on anything but a T4
6220 standard RC10/T/GT/B2/T2 axle
7221 standard B3/T3 axle - too short for an RC10 steering block without modification, posted mainly for reference
Visual reference for wide front axles
- Bottom Feeder
- Has thanked: 10 times
- Been thanked: 23 times
- Bottom Feeder
Re: Visual reference for wide front axles
Standard RC10 axles and steering blocks on the left, standard B3 axles and steering blocks on the right.
- Bottom Feeder
- Bottom Feeder
A hybrid of the RC10 steering block and T4 axle. The T4 axle uses a 3mm kingpin to it needs to be drilled out slightly to 1/8" to use a standard RC10 kingpin.
Hope seeing them 'in the flesh' instead of just a list of part numbers helps someone.
- 673 Views
Last post by justinspeed79
- 601 Views
Last post by Asso_man!
- 658 Views
Last post by Stodd16
- 38 Replies
- 3853 Views
- 256 Views
Last post by DHC6
- 855 Views
Last post by Sixtysixdeuce
- 936 Views
Last post by TheSpeedway
- 643 Views
Last post by SteveK
