My Junior 2 build
My Junior 2 build
I have an old Junior 2 that I have started resurrecting. I have most of the parts and bought a donor car off Ebay (thread here) that has most of the parts I need. I have my original Junior 2 chassis and it's in excellent condition. The donor car has a short JRX2 graphite chassis. Which one is stronger? The Junior 2 chassis feels a bit heavier but I don't think it flexes as much. It's very similar to the chassis in my LXT just wider. The front end also kicks up more than the JRX2 chassis. I've included a pic of both of them next to each other.
Mike
Kyosho Raider Pro - restoration in progress
Kyosho Double Dare - restoration to start soon...I hope
Losi LX-T
RC10T4
Losi LX-T
RC10T4
Re: My Junior 2 build
I always preferred the graphite chassis. But if you use that it wont be a Junior 2 build, right.
Yeah I guess that is true. I'll be using all Junior 2 suspension parts though. I should probably check if the body from my 2 would even fit over this chassis.minreg wrote:I always preferred the graphite chassis. But if you use that it wont be a Junior 2 build, right.
Mike
Losi LX-T
RC10T4
Losi LX-T
RC10T4
- Been thanked: 4 times
The composite chassis is far stiffer than the graphite. Keep in mind you must use the top plate with the composite. The standard JRX2 chassis has a 20 degree front kick while the rest of the JRX cars had a 30 degree. Since I don't buy into the hype of having chassis flex in some situations for handling reasons, I feel that stiffer is always better. That would mean that the composite is preferred and I myself always ran the Junior 2 chassis. I also believe however that the front kick on all 2wd cars is far too high which means I favor the stock JRX2 chassis in that regards. I like certain aspects of each but if you are intent on building a Junior 2 then you must use a Junior 2 chassis. Keep in mind that it's wheelbase and front kick were retained with the Pro-SE which was the highest performing JRX.
Thanks for the feedback. I ended up going with the compsoite chassis. Just about got everything back together last night. I noticed the front suspension is not rebounding on one side so I need to look into that tonight.fredswain wrote:The composite chassis is far stiffer than the graphite. Keep in mind you must use the top plate with the composite. The standard JRX2 chassis has a 20 degree front kick while the rest of the JRX cars had a 30 degree. Since I don't buy into the hype of having chassis flex in some situations for handling reasons, I feel that stiffer is always better. That would mean that the composite is preferred and I myself always ran the Junior 2 chassis. I also believe however that the front kick on all 2wd cars is far too high which means I favor the stock JRX2 chassis in that regards. I like certain aspects of each but if you are intent on building a Junior 2 then you must use a Junior 2 chassis. Keep in mind that it's wheelbase and front kick were retained with the Pro-SE which was the highest performing JRX.
For the most part I am using all my old Junior 2 parts. The exception has been the rear hubs came from an LXT and ball bearings in place of the bushings. I'll mostly be bashing around in the backyard with this so I'm not worried about it being a "true" Junior 2.
I don't plan on keeping the JRX2 chassis so it'll probably end up on Ebay soon.
Mike
Losi LX-T
RC10T4
Losi LX-T
RC10T4
- FasterLouder
- Has thanked: 10 times
- Been thanked: 51 times
I love the Junior cars and trucks.
Among my all time favorites and I don't have a clue why.
If you're going to use the graphite JRXT chassis,throw a 5 link rear end on that sucker,H arms just don't have that kooky,cool factor.
That is a JRXT chassis you have,right?
It'll be a mighty short ill handling bit#h if it's the JRX2 buggy chassis.
The Junior chassis have the provisions for the 5 link,hence why they are wider than the LXT/Pro SE chassis'.
All The Way Alive
I don't think there was a difference between the JRX2 and JRXT chassis. They both have the same part number.FasterLouder wrote:I love the Junior cars and trucks.
So last night I finished assembling the car, charged the battery and took it for a spin. After about 30 seconds I noticed only one wheel was spinning. Took it apart and found the outdrive is stripped on the output gear. Not sure if it's the output gear on the LRM tranny or the outdrive yet. Since I don't have a spare I decided to get a little creative with it. I put in the xx retrofit tranny I had but since I didn't have the correct length dogbones I threw on some LXT arms I had. So right now it's sitting and an LXT rear end and Junior 2 front end but it drives.
Gonna try it out tonight and see how it does!
Mike
Losi LX-T
RC10T4
Losi LX-T
RC10T4
- FasterLouder
The JRXT used a slightly longer chassis that wound up being the JRX Pro chassis.
It has a cutout for the servo saver,so they're easy to spot.
All The Way Alive
- Synergy
- Has thanked: 127 times
- Been thanked: 70 times
I'm pretty sure the early JRXT and Proformance chassis didn't have the servo saver cut out, I have a couple of them and here is one on my JRXT.
Here's my TC Showroom
- Been thanked: 22 times
SYNERGY is correct ive raced most all of the cars in my lifetime and seen both version straight out the box.DON
- JK Racing
- Has thanked: 103 times
- Been thanked: 200 times
The easiest difference (for me) to tell between a JRX2 chassis and JRXT chassis is looking at the taper going to the nose, the JRXT is straight (as seen in the pics above), the JRX2 is rounded and "swerves" of sorts. On the JR series, both buggy and truck shared the same chassis.
- Synergy
Here is a comoarison
JRX2
JRX Pro
JRX2
JRX Pro
- highwayracer
Graphite Splinters!!!!
Sometimes I would run my car on concrete...and get huge graphite splinters when I picked up the chassis. This alone would be a good enough reason to run the plastic chassis
I switched to the junior 2 chassis when I first saw it at a local trade show. When bolted together, it was much stiffer than the graphite chassis that I was running on my jrx2 (proformance kit).
Yep I ended up going with the Junior 2 chassis instead. Sold the JRXT chassis on Ebay to fund more parts! Haven't had much time to play around with it yet. Hopefully in a few weeks I have it all back to working order though.highwayracer wrote:Graphite Splinters!!!!
Mike
Losi LX-T
RC10T4
Losi LX-T
RC10T4
- 26 Replies
- 2860 Views
Last post by clm
- 2298 Views
Last post by sgirouard
- 2159 Views
Last post by hugger19
- 834 Views
Last post by FasterLouder
- 634 Views
Last post by bearrickster
- 1775 Views
Last post by LosiXXkid
- 22 Replies
- 4294 Views
Last post by Johanp
- 1183 Views
Last post by ratdude
Users browsing this forum: Amazon [Bot] and 7 guests
