Team Car vs Worlds Car (black pan)
Re: Team Car vs Worlds Car (black pan)
http://www.rc10talk.com/viewtopic.php?f=35&t=13059
However, the C stamp non milled tub was still included in the late 6035 team cars
not much help but the gold pan late CE is a C stamp also IIRC
- Has thanked: 1013 times
- Been thanked: 472 times
Allright, that begs the question, what was the difference between B & C stamp chassis?Charlie don't surf wrote: ↑Sat Nov 17, 2012 2:12 pm http://www.rc10talk.com/viewtopic.php?f=35&t=13059
I always thought the C stamp chassis was a milled B stamp.
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Late 10T's used the unmilled C stamp as well. I've got a couple of them.
- Has thanked: 822 times
- Been thanked: 2418 times
The C stamp chassis was, as mentioned above, available milled or plain. The milled version was a different grade alloy and was hard anodized. These are frequently purple by now. For the rest of my rambling here I will only be referring to the plain C not the milled. The early B and the late B had more of a difference than a late B to a plain C stamp. The early B had an offset battery holder carried over from the original A where the late B was centered. The C stamp chassis most commonly have the 6 gear holes not countersunk. There are some that are but the vast majority are not. If you held a late B and a plain C side by side you would be hard pressed to see any difference besides the countersinking.
Factory Works website
Thanks for the information. Do all original C stamps lack the counter sinking on the 6 gear holes?GoMachV wrote: ↑Thu Apr 22, 2021 6:28 pm The C stamp chassis was, as mentioned above, available milled or plain. The milled version was a different grade alloy and was hard anodized. These are frequently purple by now. For the rest of my rambling here I will only be referring to the plain C not the milled. The early B and the late B had more of a difference than a late B to a plain C stamp. The early B had an offset battery holder carried over from the original A where the late B was centered. The C stamp chassis most commonly have the 6 gear holes not countersunk. There are some that are but the vast majority are not. If you held a late B and a plain C side by side you would be hard pressed to see any difference besides the countersinking.
By a different alloy does that mean the A&B were 6061 and the C milled were 7075.
Were the nose plates also made differently?
That combination would lead to a extremely durable tub. That would have been even more expensive to produce than a regular tub.
Do you know if the Re-re chassis were also a different alloy and hard anodized?
No, as I said most lack it but not all.Do all original C stamps lack the counter sinking on the 6 gear holes?
A, B, and plain C were 6061. Worlds milled C stamp were 2024.By a different alloy does that mean the A&B were 6061 and the C milled were 7075.
The cut was different (lightened) however they did not advertise a different alloy.
I am not sure the alloy but the quality of the rere chassis was terrible. They bend much easier.Do you know if the Re-re chassis were also a different alloy and hard anodized?
- 1460 Views
Last post by DJGonzo69
- 23 Replies
- 2751 Views
Last post by mikea96
- 1181 Views
Last post by rwordenjr
- 1682 Views
Last post by sandkil
- 19 Replies
- 2145 Views
- 940 Views
- 39 Replies
- 4060 Views
Last post by Daddeo
- 1089 Views
Last post by blown5.0
Users browsing this forum: Bing [Bot] and 58 guests
