Seriously different JRX-Pro
I have wanted to do a JRX-Pro for a while, I remember BITD when I had the Team Car how badly I wanted a Pro because of the wicked box art car But, as things go I never did get one- but I have the makings of one now
Just a small taste of this car for now, still waiting on some really trick parts to add-
- losiXXXman
- Been thanked: 5 times
Re: Seriously different JRX-Pro
WOW Reg. That is TIGHT! What is it, and where DID you get it? INSANE!
- Has thanked: 7 times
- losiXXXman
I'd never seen it with 'weave" Is that a vinyl stuck on the the regular factory pro chassis?
- losiXXXman
Well, I'd never seen one before. I thought pretty much all pro and T chassis were the same, save the servo saver clearance hole. My T BITD was just flat black, no weave. I thought they were all like that.
Well, it's dimensionally the same, and it is 3mm with a white fiberglass core and is stiff as a board and is really rigid over the already stiff regular JRX-t/Pro chassis- BUT both the other chassis that I have are early non servo saver type's so that may make a difference-
Wow - hadn't heard of them before!! I have seen one off and short production carbon chassis - but nothing like this one.
Looks identical (even the white fibre core is the same)!
Certainly is pretty
Cheers,
Darryn
Certainly is pretty
Cheers,
Darryn
I am definitely hoping to see a 5-link set-up on this bad girl.
In process build pics would be neat, as available.
I'm guessing that is will not be a runner ...
H arms in the rear, but I will leak this out for the build...........look for a plethora of NIP MIP parts on her
- 770 Views
Last post by cas22
- 1081 Views
Last post by Momo5
- 1122 Views
Last post by Bongo Fury
- 3302 Views
Last post by RCveteran
- 23 Replies
- 2798 Views
- 1192 Views
Last post by crazy nick
- 689 Views
Last post by cas22
- 959 Views
Last post by mrlexan
Users browsing this forum: No registered users and 18 guests
