Some Cougar variations
- DerbyDan
- Been thanked: 17 times
My poor Cougar 2 Works has been sitting on the shelf getting dusty... ever since it arrived from BORMAC in Australia back to Northamptonshire, UK. from its around the world trip.... It had also developed a leaky front shock, so it was about time I gave it a freshen-up
Anyway - I dissmantled the front end & have brought a replacement front bulkhead (still available from Schumacher) I thought it would be interesting to show the differences between the old & the newer part... i'm also pretty sure that there are many other variations that have been made to this one part - the one on my original Cougar 1 years ago, certainly didn't have the holes to fit the Storm or Road & Track body mounts - i'm not even sure it had those wedge shaped fillet peices on the inside faces?.. note also how the groove underneath has been in-filled where the part flexes to give different caster angles/front kick-up.
I also got a small amount of Schumacher spares with a bunch of Losi parts a friend gave to me.. amongst them were some front hubs, the casings/bearing retainer part on them seemed evidently a little deeper than the hubs I had just dissmantled from the Works car.... on dissasembly I realised that these where the double bearing version, as shown below nearest the camera..
I remember once seeing this set-up being sold on ebay - but I don't know whether this was an 'Options' part or a set-up developed later on after the Cougar series for cars like the Big6...... similarly for the bulkhead part? Obviously with the deeper assembly this also widens the track of the car a little.
P.S; I also got what I think is the original Schumacher slipper clutch assembly but I forgot to take a photo of it, i'll have to take a picture so that someone can identify it
P.P.S; If anyone has one single steering arm/hub for a Cougar (as shown above) Please let me know
- Incredible_Serious
- Has thanked: 1406 times
- Been thanked: 861 times
Re: Some Cougar variations
That twin bearing front hub upgrade was developed after the release of the Shotgun, when Schumacher realised that the single front bearing was a bit weak with big truck wheels on the front.... a great upgrade for any truck, but not sure if really needed for a simple Cougar.... unless you're looking for a little extra width
Must check to see what is on my Big6.....
- DerbyDan
Sounds about right Alex - though I can remember re-building my mate's Nitro 10 truck & that didn't have the twin bearing set-up? Maybe it came with later kits & the ShotgunII? I'm guessing the twin bearings was more about reducing slack by introducing two bearing surfaces for the wheel to run on - the original single NMB bearing I think was about the same size as the ones we put in skateboard wheels - so I don't think the bearing itself would ever fail.Incredible_Serious wrote:That twin bearing front hub upgrade was developed after the release of the Shotgun, when Schumacher realised that the single front bearing was a bit weak with big truck wheels on the front.... a great upgrade for any truck, but not sure if really needed for a simple Cougar.... unless you're looking for a little extra width
I wanted to fit the double bearings to my Cougar as there is quite a bit of 'play' in the front wheels, just to try it out really - the track width difference is only about 1mm each side. But unfortunately I think Jason has used slightly larger (but shorter) screws to fit the bearing cover - which means the longer (but smaller dia) Schumacher screws wont thread into the current hubs/steering arms (Part # T328) - I have one spare one that will work but I need another....
While I said it was a development after the Shotgun, I never said it was standard..... none of the Nitro 10s had them, nor did the Storm, or any of the Cougars. It was an option on everything that ran those front hubs.
I would have to have at least 3 or 4 new hubs in my parts lots.... PM me an address and I'll drop one in the mail.
Yup those bearings used in the older Schumachers were 16x8x4...same ones used in 1/8 buggies. Pretty much overkill for 1/10 cars but for load purpose dual bearings (even if smaller size) are much better of course.
- DerbyDan
I've got it all back together now, took some pictures this lunchtime since the sun was shining
Paintwork courtesy of BORMAC
Mmmm purple!
Wear underneath
Love the Cougar2 shape!
Despite putting in some new plastic spigots, there's still plenty of 'slop' in the front wheel bearings so will swap the hubs for double bearings as soon as I can
Mmmm purple!
Wear underneath
- 599 Views
Last post by FasterLouder
- 1783 Views
Last post by CraigB
- 104 Replies
- 19250 Views
Last post by JK Racing
- 1567 Views
Last post by juicedcoupe
- 553 Views
Last post by terex
- 645 Views
Last post by Erich Reichert
- 876 Views
Last post by Phin
- 537 Views
Last post by fleetwood472
