RC10 Factory Team Turnbuckle Set
The B3 Factory Team Turnbuckle set works on the graphite, worlds and champion edition buggy, im sure it will work for the original goldpan too.
1207- B3 Turnbuckles - 25.00 from Towerhobbies
individually:
2 Rear- 2.00"- 1406
Centerlink- 1.00"- 1409
4 Front- 1.65"- 1403- this one is only at rc10.com they come in 2 packs
Then you will need an extra 1402 for the servo link to steering block
individually:
2 Rear- 2.00"- 1406
- mrhemi1971
Re: RC10 Factory Team Turnbuckle Set
The B3 set will not work on a tub car, they would all have to be trimmed except the 2.0 for the steering,
Rc10 Tub chassis-
Front camber links 1.65"
Rear camber links 1.35" stealth, 1.0" 6 gear
Steering 2.0"
You can get close by ordering individually via AE or tower the current 1.33/1.68 etc-long RPM or Losi ball cups will change the length
Rc10 Tub chassis-
Steering 2.0"
wait the original tub i wasnt sure about, but the others is what the dude from Team Associated said the would
The 6010 short arm 6 gear is
Front camber link 1.0
Steering links 1.35
Rear links 1.0
Steering links 1.35
Rear links 1.0
- Has thanked: 23 times
- Been thanked: 9 times
Man how Cool! I have asked this question alot on here with no answer!? Thanks for the info
- mrhemi1971
I was thinking of putting plain finish ones on my goldie. Thanks for the info.
ASSOCIATED OR NOTHING!!
I can't find 1.33/1.35 turnbuckles anywhere. I want to outfit a short arm rc10. I was planning on using Lunsford Punisher 1.0" turnbuckles/cup kit for camber, will the 1-3/8 work for steering? I know that's 1.375", and I want a little bit of toe out in the front. Can I compensate by screwing the balls on farther? If not, can I use FT 1.30" blue turnbuckles, or are they too short? I looked at the Du Bro turnbuckles, but I'd rather have titanium if possible.
- Has thanked: 10 times
- Been thanked: 447 times
either option is probably fine. I'd suggest getting them a little longer, and if necessary, trim a tiny bit from each end. you can take away, but you can't add.
Okay, thanks. The Du Bro turnbuckles are a lot cheaper. I was looking at the Lunsford for durability. Does anyone have experience with the durability of the Du bro 4-40 turnbuckles? Are they at least as strong as the stock threaded rods?
Thanks, good to know. I've never bent a threaded rod, so I guess the Du bro turnbuckles will do fine.
- 1791 Views
Last post by PBR Allstar
- 640 Views
- 433 Views
Last post by metallicats33
- 605 Views
- 1008 Views
Last post by broodenburg
- 698 Views
Last post by KidAgain
- 42 Replies
- 4611 Views
Last post by shaveradam
- 44 Replies
- 3835 Views
Last post by Daryl Lane
