stupid question
stupid question
i am going to be buying a mod motor lathe. what is better v block or bearing lathe i am looking at the entegy mod fasion motor lathe with bearing support. what is the best and why? i have found one for 39.99 plus shipping.
Thunder Turtle Racing
- Been thanked: 12 times
Re: stupid question
I think that the v-blocks are supposed to be better. It has something to do with the precision/vibration of the bearings. I have an older xipp/integy mod lathe with the bearings, and it seems to work just fine.
Unless you are competing at a high level and need your motors to be tuned to perfection, it probably doesn't matter which kind of blocks you get.
Re: stupid question
I am looking for one too. $40 seems a good price. Where did you find it?
Re: stupid question
V-blocks, as they have they least amount of play possible, they will ALWAYS be better than anything else. -Jeff
Re: stupid question
Ebay.8rad wrote:I am looking for one too. $40 seems a good price. Where did you find it?
Re: stupid question
well i have found another. is the trinity twister motor lathe anygood? i found one for 60.00 bucks with slave motor and dimond bit. should i go for it? Thanks
Re: stupid question
If the seller is local, you want to check to make sure there is no abnormal binding or play on the guides. Also check the bit to make sure the diamond tip is not chipped off. Ideally, have the seller do a quick cut before you pay him (comm sould be smooth satin finish). Good luck!
- MOmo
Re: stupid question
I have an older trinity lathe, and I like it. I need to re-wire the on/off switch.
Like an idiot, i dropped my diamond bit. Its not cheap to get them thru trinity, does anyone have a cheap source for getting a bit re-done? I'm finally stepping up and getting a BL system, but I have quite a few brushed motors I don't want to give up on just yet.
MOmo
MOmo
Re: stupid question
just buy the proper size carbide bit. they are like $4 through tool places like mcmaster.
If you are only freshening up old motors no need to drop the $$ on diamond. besides many will argue that a carbide tip is as good if not better than diamond. From what I've read the skill of the user is more important to the final finish on the comm than the choice of tip material.
Given my lack of skill I stick with the $4 bit myself.
http://www.rcottawa.com/index.php?topic=53.0;wap2
- civilguy
- Has thanked: 3 times
Re: stupid question
I have to agree with Anthony... not that I don't usually.
I have both bits and not being a pro racer I can't tell the difference between the results. Be patient and only shave off a tiny bit at a time... you'll be good to go. I have eeked out a ton of life from my old motors.
Jeff
Jeff
Re: stupid question
I just picked up a used Hudy lathe on eBay, should be here within a week. I've used regular lathes before so use is no problem, but how small can I cut the comm before they are too small? I've got some older motors I'll try and revive before I toss them.
- Has thanked: 7 times
- Been thanked: 41 times
Re: stupid question
That's right for the regular diameter comm's but there are some in-between sizes out there that you have to watch out for. The Reedy Quad Mag 19 turn, the Reedy Krypton's and Ti Worlds, and the old Sonic's.dldiaz wrote:I am not an expert, but, I think smaller than about 0.270", is not really worth trying to revive.
- 643 Views
Last post by Hillbillyrcer
- 758 Views
Last post by Cooperd82
- 925 Views
Last post by terry.sc
- 1552 Views
Last post by JK Racing
- 906 Views
Last post by littleVETTE
- 594 Views
Last post by Jerzi
- 1647 Views
Last post by rraeford
- 27 Replies
- 2998 Views
Last post by wyldbill
