What size are the balls and are they the same size as the ZX-5 balls? I want to get some for my two runnersj0pp3 wrote:
For a serious runner it's possible to replace the diff balls with modern ceramic balls.
/j0pp3
Turbo Optima Mid + Turbo Optima Mid SE build/restore
Re: Turbo Optima Mid + Turbo Optima Mid SE build/restore
- Been thanked: 288 times
Thanks Jeff and j0pp3. I did as recommended, black grease for the thrust and Kyosho diff grease for the ball diff.Jay Dub wrote:I have always been a fan of the associated stealth grease for the diff, and black grease for the thrust. -Jeff
I'm still unclear on how to properly adjust the diff, though...the aforementioned instructions are useless because "the diff body should not turn idly" is arbitrary and makes no sense. I got the diff outdrive on one side to reverse-rotate nice and smooth to the other side, but it seemed otherwise to be quite loose--maybe that's how it's supposed to be? When I tighten it even just a bit more, the reverse-rotation seems to have too much friction/resistance, and a bit more tight and it feels scrapey, which can't be right.
How do you guys recommend adjusting the ball diff, in empirical terms if possible?
If its any help I have had Fibrelyte make me this SWB chassis, along with some other custom parts which will turn up in my thread if I start this build next now the SP is nearing completionj0pp3 wrote:Thanks!uniquenamehere wrote:Wow...nice work with the dremel!
Word! Next part to create will be a Rear Plate (L). For that I will use an OT-114 as a blueprint even if I won't use it to mount a mechanical speed control. And after that I may try to do my own chassis designed to use saddle pack LiPo's but by then I think my runner will have it's own threadJerzi wrote:Very nice parts.
With dremel you can do what ever you want. And the finish is superb.
Jerzi
- tintin74
- Been thanked: 23 times
Hey Joel,
Would you mind if I posted this build on my Website?
www.kyosho-optima.com
I will give you credit and link back to the forum thread.
Thanks.
Thanks.
Check out http://www.kyosho-optima.com and my Facebook Group https://www.facebook.com/groups/optimaseries/
- Lavigna
- Has thanked: 797 times
- Been thanked: 1041 times
This is an amazing thread. It deserves a bump.
My Photo Gallery --->https://www.rc10talk.com/viewtopic.php?f=77&t=38934
- Bakauata
- Has thanked: 35 times
Damn right! Thank you for doing that. I just read the whole thing. Amazing.Never seen anything like it. I need to step up my game! Congrats to the OP.
Chris
- Lavigna
Such a shame that all the incredible pictures from this thread are gone.
- radioactivity
- Has thanked: 345 times
- Been thanked: 516 times
The build thread still lives on here https://www.kyosho-optima.com/midse.html
I referred to it many times during my ongoing Turbo Optima Mid SE thread.
Chuck
Chuck
- Garage Hack
- Has thanked: 136 times
- Been thanked: 5 times
Thanks for hosting all of that! It is such a bummer when images go away and I appreciate you archiving posts like this.radioactivity wrote: ↑Sat Sep 25, 2021 5:58 pm The build thread still lives on here https://www.kyosho-optima.com/midse.html
Chuck
- 44 Replies
- 8056 Views
Last post by Wahrsuul
- 49 Replies
- 7235 Views
Last post by nvxwax
- 52 Replies
- 10438 Views
Last post by HKS_TRD
- 19 Replies
- 6385 Views
Last post by lin6499
- 2002 Views
Last post by Bo Wallen
- 1149 Views
- 1071 Views
Last post by GJW
- 61 Replies
- 9644 Views
Users browsing this forum: Google Adsense [Bot] and 15 guests
