What I thought it was mineTHEYTOOKMYTHUMB wrote:WOW! One for you and one for me! Thanks buddy!
My 2012 Vonat Builds (2WD) (02/18/12)
- bearrickster
- Been thanked: 5 times
Re: My 2012 Vonat Builds lol
- nvxwax
lmao, well now i wont have any lolbearrickster wrote:What I thought it was mineTHEYTOOKMYTHUMB wrote:WOW! One for you and one for me! Thanks buddy!
- soniccj5
Those look great!! I hope you are going to bring enough for entire class in CT.
ED
ED
- nvxwax
lol, well i will be bringing at least one, and a race clod just for fun Im still sorting out what to do with the clod
- nvxwax
Ok well i have installed the A&L Chassis stiffeners, I had to improvise a little, I did not realize the front had to be mounted to the inside of the nose tubes, I had them notched to let the stiffeners lay against the chassis sides. i just used a stainless nut to fill in the gap. If i installed them like i originally planned it the plates would be to fare apart to use the battery strap.
would it work better if you switched the nose tubes around from left to right? thet way the notch would be on the inside of the chassis then you could eliminate the nut. or would the braces still be too far apart?
- Asso_man!
- Has thanked: 40 times
- Been thanked: 70 times
Yes very clean and thought of builds. Gear covers are RPM.aoH wrote:so clean!
what gear covers are those?
Come and visit the stable
- nvxwax
Thanks guys,
I have a low cost brushless system on the way for testing, Its a off brand but the colors match the project lol, If they do not perform well i will move them to the shelf car and get a proper brushless system for the runner car. I have a new Futaba 3pm 2.4 radio i will be using for the runner also, Im not even sure where i got it from but it will work fine for my uses.
I might try that, It will be close lol, I dont want any lipo's flying outwyldbill wrote:would it work better if you switched the nose tubes around from left to right? thet way the notch would be on the inside of the chassis then you could eliminate the nut. or would the braces still be too far apart?
Yes, they are RPM B4 covers, You have to drill the motor plate for one of the mounting holes.aoH wrote:so clean!
yay! thanks! time to order up some b4 covers, didnt think they would fit.
- soniccj5
I am planning another revision to my buggy, and was looking at a set of these stiffeners. I am worried the bullet style 96mm LiPo will not work though.
What type of LiPo are you going to run, and have you already test fit it?
thanks,
ED
thanks,
ED
- nvxwax
I have a Venom 35C 7.4V 3800mAh 2S Hardcase LiPo and it fits pretty good, That is the highest mAh i could find that would fit under the top brace.
Dimensions: 23.3 x 46.75 x 137.85mm (0.92" x 1.84" x 5.43")
The battery is not pushed into the rear bulkhead, It will go in a little but its tight with the top brace on.
- soniccj5
Thanks for the pictures.
It might be a tight fit, but I think with a bit of work I can fit my 3800 60C 96mm LiPo.
- 955 Views
Last post by soniccj5
- 161 Views
Last post by Dangeruss
- 370 Views
Last post by markt311
- 132 Replies
- 9720 Views
Last post by RETRO R/C
- 1392 Views
Last post by SFC K
- 47 Replies
- 2521 Views
Last post by vintage AE
- 28 Replies
- 3035 Views
Last post by Tomas Karlsson
- 680 Views
Last post by flipwils11
Users browsing this forum: Ahrefs [Bot], Google Adsense [Bot], juicedcoupe and 48 guests
