- Diamond Dave
- Has thanked: 567 times
- Been thanked: 103 times
No manufacturer or brand markings anywhere, Aristo Craft Hitec servo hs-300 and an AM receiver hp-2rnb.
Tires have "Off-Roader" on them, Mabuchi 540-HS motor. Just not familiar with this design, I am thinking it is Futaba, but no idea what year or model. [/img
- morrisey0
- Has thanked: 54 times
- Been thanked: 1272 times
- Diamond Dave
Just like ferals and you took them in. Haha! Thanks for this.
I thought Futaba. Mid to late 80's it is.
- Frankentruck
- Has thanked: 1590 times
- Been thanked: 1770 times
Anyone recognize this aluminum end bell? I feel like it should be for an Atlas motor but really have no idea.
- LowClassCC
- Has thanked: 89 times
- Been thanked: 104 times
Picked up a Tamiya Blackfoot roller and it has these aluminum shocks on the front. Anybody seen them before?
- MarkyDents
- Has thanked: 1361 times
- Been thanked: 511 times
Nope but it sure is purrtyFrankentruck wrote: ↑Fri Aug 11, 2023 10:37 pm Anyone recognize this aluminum end bell? I feel like it should be for an Atlas motor but really have no idea.
Hey Cru ! Go balls out
- MarkyDents
I’ve got a pair myself that had ironically come on a frog I picked up like 25 years ago lol. Looking forward to someone knowing too.LowClassCC wrote: ↑Mon Aug 14, 2023 3:04 pm Picked up a Tamiya Blackfoot roller and it has these aluminum shocks on the front. Anybody seen them before?
- Has thanked: 553 times
- Been thanked: 381 times
Tamiya racing hop up shocks for the grasshopper hornet etc sorry don’t know the part numberLowClassCC wrote: ↑Mon Aug 14, 2023 3:04 pm Picked up a Tamiya Blackfoot roller and it has these aluminum shocks on the front. Anybody seen them before?
Here’s a link that might help
https://tamiyabase.com/forum/11-technical/17943-wazzup-with-vintage-frog-shocks
- LowClassCC
That's good enough for me. Thanks Retro rcRetro rc wrote: ↑Mon Aug 14, 2023 3:20 pmTamiya racing hop up shocks for the frog Subaru brat etc sorry don’t know the part numberLowClassCC wrote: ↑Mon Aug 14, 2023 3:04 pm Picked up a Tamiya Blackfoot roller and it has these aluminum shocks on the front. Anybody seen them before?
Looks like they came as standard on the original release frog but have been changed slightly on the re releases, different springs and black top eyelet
- MarkyDents
Btw your Blackfoot has a frog chassis, it’s life may very well have started out as a buggyLowClassCC wrote: ↑Mon Aug 14, 2023 3:04 pm Picked up a Tamiya Blackfoot roller and it has these aluminum shocks on the front. Anybody seen them before?
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
The new shocks have a similar look but are a complete different design.
Some people don't like the re-re Frog shocks. I think that the springs are the biggest problem. But you can use RC10 front black springs with the included plastics and they are okay. No shock will make an ORV great.
- LowClassCC
yep. I did get a couple red chassis pieces with it also. I know they changed the gearing from the frog to the blackfoot due to tire size so I plan to start counting teeth as soon as I can find an original blackfoot manual.MarkyDents wrote: ↑Mon Aug 14, 2023 3:35 pmBtw your Blackfoot has a frog chassis, it’s life may very well have started out as a buggyLowClassCC wrote: ↑Mon Aug 14, 2023 3:04 pm Picked up a Tamiya Blackfoot roller and it has these aluminum shocks on the front. Anybody seen them before?
- juicedcoupe
They are easy to identify. Blackfoots used a one piece counter gear, while Frogs had a two piece. The Blackfoot should also have a motor adapter plate and long 10T pinion gear.LowClassCC wrote: ↑Mon Aug 14, 2023 7:56 pm I know they changed the gearing from the frog to the blackfoot due to tire size so I plan to start counting teeth as soon as I can find an original blackfoot manual.
Frogs had three gear ratios available. The one that uses the 52T gear is actually compatible with the Blackfoot adapter and pinion.
- 59 Replies
- 8644 Views
Last post by Diamond Dave
- 102 Replies
- 15637 Views
Last post by mikesofunny
- 431 Replies
- 39500 Views
Last post by Eccentric
- 67 Replies
- 8961 Views
Last post by bearrickster
- 448 Replies
- 35994 Views
Last post by MelvinsArmy
- 321 Replies
- 27897 Views
Last post by tazz888
- 351 Replies
- 34756 Views
Last post by Frankentruck
- 2205 Views
Last post by mrlexan
