Championship Edition
Re: Championship Edition
just ordered a complete set on ebay for $6.59... I'll have spare gears if I ever need em I guess.
I am not sure about that. My current gears are on their 3rd motor.
I have been using them since 1992, they have never been replaced.
In fact this is the first time I have had the tranny apart.
- soniccj5
Wow!! I can not count how many gears I went through bitd. Still good to have a spare set though.
ED
ED
spare parts are never a bad thing.. true
I am curious. what do you all recommend for lube for tranny (in and out)
Also, what about the felt dust seals? What do I replace those with? Mine were worthless and fell apart pulling them out.
- JHarris
Run the inside dry and use Associated lube on the diffballs in the spur gear. Replace the felt seals with bearings.
dry inside? wow!
I thought you would do something in there, but ok.
where the felt goes... is that the "outdrive"?
oh, can I replace the bushing in the rear hub with a bearing? That bushing is kinda long
You can replace the bushing with 4 1/4 x 3/8 Ceramic Flanged bearings
http://www.avidrc.com/product/9/standard-bearings/112/14-x-38-Ceramic-Flanged-Metal-FR168ZZC-standard-bearings.html
Morten Max
- Has thanked: 28 times
- Been thanked: 957 times
yes, four. 2 for the outside, and 2 for the inside.campbuds wrote:It takes 4 to replace the two?
- Has thanked: 10 times
- Been thanked: 447 times
yep, everything that everyone has said is good to rebuild stock.
Or, you could add the 3/8" x 5/8" outdrive bearings, and do this mod to get rid of the extra inner bearings.
http://www.rc10talk.com/viewtopic.php?f=38&t=13836
So, I got the care package yesterday. I will be using the bearings I got for the rear axles.
Here is what I got and what I need. Progress is slow but worth it. I am looking forward to getting it back on the road!
This is what I have have thus far courtesy of JHarris
This is what bearings I need to replace
I need a bearing to fill the gap here? This is where the felt seal was.
According to this I need two bearings here... I see the mod, don't want to bother. Seems to me I need more bearings than we mentioned earlier in this thread (I could be mistaken)
anywhere else I can get a good deal on bearings? avidrc.com is out of stock on the most needed bearing 3/16x5/16 flanged.
- 999 Views
Last post by MOmo
- 29 Replies
- 3379 Views
- 32 Replies
- 3425 Views
Last post by DaveM
- 752 Views
Last post by cyberfox
- 742 Views
Last post by juicedcoupe
- 26 Replies
- 4962 Views
Last post by joey_zrl
- 406 Views
Last post by isaidme
- 759 Views
Last post by hkp
Users browsing this forum: Dangeruss and 9 guests
