Yokomo MX-4........ Restore or part out?
- mtbkym01
- Has thanked: 169 times
- Been thanked: 128 times
Re: Yokomo MX-4........ Restore or part out?
Polished and polished and polished the chassis
The underside looks great
And my shock towers (BezerkRC) and Spur have arrived. Still waiting on a set of rear uprights and hubs. Then I will need to order a bodyset, and looking at wheels and wings from JC Racing.
I was doing some test assembly, and discovered the RHS lower bulkhead is broken, I didnt notice this on disassembly so will be sourcing this next
- mtbkym01
Didn’t realise I hadn’t posted this pic here, the 2 front hubs were very worse for wear, I have a new in pack pair on their way to me
- mtbkym01
The kit specific lower bulk head parts are impossible to find, and although there is a 3D printed option, I decided to research other Yokomo parts, and found that ZS-300RTG (For the MR4-TC) bulk head parts are very very similar. I was able to locate NIP parts locally (again) so grabbed them today. The upper bulkhead part is identical to the 2 I already sourced, so now I have 3. These new parts are carbon reinforced which is a bonus. But…….the RHS is slightly different. The circled bit in the pic below will interfere with the slipper assembly, so a grabbed the dremel to remove it. Will tidy it up a bit, but now the parts will work fine.
I’ve also started assembly of front and rear diff’s and the slipper assembly
Using all new bearings
- Alex B
- Has thanked: 13 times
- Been thanked: 31 times
mtbkym01 wrote: ↑Tue Jan 23, 2024 1:15 am The kit specific lower bulk head parts are impossible to find, and although there is a 3D printed option, I decided to research other Yokomo parts, and found that ZS-300RTG (For the MR4-TC) bulk head parts are very very similar. I was able to locate NIP parts locally (again) so grabbed them today. The upper bulkhead part is identical to the 2 I already sourced, so now I have 3. These new parts are carbon reinforced which is a bonus. But…….the RHS is slightly different. The circled bit in the pic below will interfere with the slipper assembly, so a grabbed the dremel to remove it. Will tidy it up a bit, but now the parts will work fine.
I had to file that part when I modified the MR4 -BC bulkhead for the LWB conversion I did on it, I also fitted the MX-4 slipper. It didn't occur to me until you posted the photographs that the mod was also needed to accommodate the slipper.
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
It's going to start looking like a car soon
- mtbkym01
Should see the stack of Yokomo Header Cards I’ve accumulated
- mtbkym01
The rear hubs (orig) that i had on order didnt turn up, so have been refunded. Now waiting on a set from Rubrix Racing. Still need to finalise some electronics (might just put some generic cheapie in for now while I consider and search for something better. Still need body, undertray and wing, and a JC Racing wing and some wheels.
- RC10th
Looks great Kym, all your hard work has paid off !!
- mtbkym01
Thanks RJ, pretty close now, need a better ESC, this one is getting very hot and smoky , even on nimh. Body, more wheels and wings incoming.
- mtbkym01
JC Racing wheels and wing, paint and Tekin Pro Star ESC to go and this is done
- RC10th
Wow, that's fantastic !
Great job Kym, definitely has the old racer look to it !
- 66 Replies
- 5813 Views
Last post by Peakey
- 1022 Views
Last post by shodog
- 1425 Views
Last post by carloco8
- 2109 Views
Last post by aip47-2008
- 1004 Views
Last post by obsidian
- 942 Views
Last post by Alex B
- 596 Views
Last post by Dual
- 912 Views
Last post by a01butal
