Bored? Come To The Chit / Chat Thread
- Frankentruck
- Has thanked: 1589 times
- Been thanked: 1770 times
Re: Bored? Come To The Chit / Chat Thread
I use a 4-40 T-nut that I trim the brad tips off of. The get trimmed to the shape/size I need.
- TRX-1-3
- Has thanked: 1399 times
- Been thanked: 764 times
OK that's promising. I'm looking for a cone because it's for a backwards application where a tapered screw usually goes. Basically I'm abusing the use of the forum in hopes that someone says, "Yes Mark, these work for your application. I have used them many times and the results are always perfect."
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
https://www.amainhobbies.com/custom-works-256-cone-spacers-4-csw5232/p1274901
These are brass and will easily drill and tap.
I typically drill them out for applications that require more clearance than a larger 4-40 or 3mm conical spacer provides.
- MarkyDents
- Has thanked: 1361 times
- Been thanked: 511 times
I’m not sure why they would say it to me…… you’re the one that asked
Hey Cru ! Go balls out
- Has thanked: 946 times
- Been thanked: 563 times
- TRX-1-3
Ding dang it! Makes me want to find 4.3 × (x) x3mm ball studs.! Makes me want to dump Tra**as as my nostalgic RC thing!!!!!! But thank you. Seriously, thank you.
- Lowgear
- Has thanked: 78 times
- Been thanked: 596 times
That's likely the case. Maybe it's something to look into changing.
- morrisey0
- Has thanked: 54 times
- Been thanked: 1272 times
I have never been able to properly state my dislike of low profile tires on trucks as well as this picture does.
- Halgar
- Has thanked: 145 times
- Been thanked: 189 times
Giant rims and low pro tires on anything are ridiculous, not to mention dangerous in many instances.
- morrisey0
Picked this lot of tires up from the local Flea Market this past weekend. $15, and the seller was happy to get rid of them! I can get rear 1/10 donuts from a local guy all day long for $7.50 a pair, so the Bolinks aren't all that exciting, but two rear sets + one front set for a Traxxas Bullet and a front set for a Cat ................... and then just some funky a$$ aj's front offroad foams made it a no brainer!!
- Frankentruck
I need to start shopping for fleas
- morrisey0
I am convinced that there is just one local guy, into vintage RC cars, that hits all the local yard sales, garage sales, flea markets, estate sales, swap meets, etc about 30 minutes before I do! The time I have into these is not worth the juice, but man is it fun to try!
- 53 Views
Last post by Dangeruss
- 497 Views
Last post by fastang
- 730 Views
Last post by slotcarrod
- 472 Views
Last post by THE H.P FREAK
- 1392 Views
Last post by rocketrandylee
- 34 Replies
- 3393 Views
Last post by WillyThickfoot
- 23 Replies
- 1544 Views
Last post by Goatless
- 206 Replies
- 9599 Views
Last post by purpletimbo
Users browsing this forum: No registered users and 31 guests
