RC10t from the ground up with an RC Carbon Works chassis
Re: RC10t from the ground up with an RC Carbon Works chassis
Seeing how evaporust does on the extra, rusted 1/4" MIP 1008 kit. The rust isn't that bad but if I can get rid of it I'd like to. Looks like one of the fluid packs (thread lock maybe) busted in the bag about 10 years ago:
- Has thanked: 750 times
- Been thanked: 26 times
Hi,
Hopefully it will come off,
is it rust or dried residue from the thread locker?
- klavy69
- Moderator
- Has thanked: 561 times
- Been thanked: 265 times
You can pick up new GPM(?) nose plates for the gt on ebay which will work. I think I seen silver, blue, purple, and red annodized over the weekend. No factory AE black of course unless you wanna pay out the nose...
I saw the blue GPM one... there's like a factory bare one on eBay as well I've considered since it would be the only aluminum part on the truck?
I pulled the CVDs out and the rust came right off... as I expected the finish came off a little too. They're now a silver color whereas before they had like a black outer coating that was more like the finish on a stove burner than a paint? That said - is there a coating I should attempt to stick back on top of these to prevent rust? I was trying to avoid wd40 that attracts all sorts of first and dust... I've heard people talk about using stuff on guns to reblack or reblue the barrels? Is that something you can get and rub on?
Picked up an RPM transmission that I'm planning on dying black... in the listing it actually looked white. It as it turns out it looks to have been previously dyed light grey. I'm assuming dying black won't be an issue? I was planning on using Rit dye but am certainly open to anyone's expert advice here!
- Has thanked: 822 times
- Been thanked: 2418 times
gray was the oval gear ratio trans, white was the truck ratio. I am not sure if it would take dye the same, but I would expect it to
Factory Works website
Crap did not realize they made multiple versions?! So I clearly messed that up! Whats the oval ration vs truck ratio?GoMachV wrote:gray was the oval gear ratio trans, white was the truck ratio. I am not sure if it would take dye the same, but I would expect it to
Gray case is a 1.96 and the white truck case is a 2.65
So does that work like an actual car? Lower gearing = higher top end?GoMachV wrote:Gray case is a 1.96 and the white truck case is a 2.65
It just lets you run more realistic pinion and spur combos.
The white case is better for truck tires, it's a deeper internal ratio
Lower ratio number ( :1 ) is higher top speed given the same gearing externally
I actually just came across that thread! So it does appear I got kind of an oddity/rarity when it comes to truck transmissions!
Hi,
Some info here about the 1.96 RPM trans, need to read down to about the middle of the page.
http://www.rccaraction.com/blog/2014/04/08/classic-plastic-richard-royall-and_rpm/
- 25 Replies
- 2988 Views
Last post by firebird1999us
- 2172 Views
Last post by Ucsdmutt
- 3106 Views
Last post by phoenix
- 1020 Views
Last post by shodog
- 29 Replies
- 4960 Views
Last post by EMC
- 2024 Views
Last post by durb69
- 26 Replies
- 2512 Views
Last post by Chewbacca
- 736 Views
Last post by RS Chris
Users browsing this forum: Amazon [Bot] and 9 guests
