The start of something new (Quadra car)
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 19 times
Re: The start of something new (Quadra car)
Looks great Joey!
You've got to ditch those bushings in your steering though
- JK Racing
- Has thanked: 103 times
- Been thanked: 200 times
The bushings are polished as well as the plastic inserts...pretty darn amazing with a little elbow grease and fiddling will do with bushings.
- Has thanked: 822 times
- Been thanked: 2418 times
I always liked bushings better too those thin bearings would fall apart all the time
Factory Works website
- JK Racing
Little late night work...now just paint and electronics to finish it up.
Loving everything about this build!
Isn't the front "too wide" to be legal with the b4.2 caster blocks on the quadra arms?
looks good. explain to me what the quad set up is gonna do for handling?
- Niki
- Has thanked: 3 times
- Been thanked: 36 times
Most likely too wide bacause arms were designed for RC10 caster blocks with #6220 axles.
NIXconcepts -Shapeways Shop- -I.materialise Shop-
--- Quadra-symmetric RC10 --- RC10 '91 Worlds Conversion --- Start of NIX91 story...
- JK Racing
I'll measure, if it is too wide, it may only be off by a couple mm. I have narrower hexes to use if I need to.
- JK Racing
Its a move toward newer style suspensions where the front and rear arms have the same hinge points both inner and outer. Niki may be able to explain what it does better, but basically, its a long arm version of the rc10twisted wrote:looks good. explain to me what the quad set up is gonna do for handling?
whats needed besides the arms to convert from a regular rc10? rc10t bulk head and??
- JK Racing
RC10T or GT nose plate, bulkhead and nose tubes. NIX Concepts (shapeways or i.materialize) quadra arm set up, narrow front tower (or RPM clone, or RC10T/GT).
Time & a donor car
Time & a donor car
Looks awesome! What would happen if you used a regular RC10 nose instead of the truck? Too wide?
It would be too wide and defeat the whole Quadra base
Please let us know, because I would be very interested in being able to use my B5M's hex front wheels on my quadra car at some point... but it has to be ROAR legal because (at least here) when you beat people with a gold pan they want to look at your car closely; nobody wants to be called a cheater. Now I wish I still had a b4 so I could just measure itJK Racing wrote:I'll measure, if it is too wide, it may only be off by a couple mm. I have narrower hexes to use if I need to.
- JK Racing
JasonB, I measure the top of the tires are at 250, the bottom about 253, so just a hair outside ROAR limits.
- 177 Replies
- 37177 Views
Last post by Niki
- 705 Views
Last post by kfeldt
- 784 Views
Last post by yellowdatsun
- 1961 Views
Last post by Mr. ED
- 874 Views
Last post by Faux4x4
- 1142 Views
Last post by bjammin90
- 19 Replies
- 1428 Views
Last post by bearrickster
- 1354 Views
Last post by uniquenamehere
Users browsing this forum: Bing [Bot] and 32 guests
