Another Vintage done!!!! MRP Kong!
- old_rc_lover
MRP Kong. Finally got around to completing it. Still looking for a transmitter tho.. Need an old Aristo Craft 27 Mhz to match receiver. Here are some pics. Luckily it is a take off of the Hirobo Rock'n City. So spares are easier to come by than if it were a one off kit. In fact it is exactly the Rock'n City RC buggie. Just has bigger tires, added engine plate with another belt to lower gearing and a front shock mount/body mount. Everything else is Hirobo. The plastic belt protector on bottom even says Hirobo....???!!!!
Re: Another Vintage done!!!! MRP Kong!
That's a really nice Kong! I noticed they run the upper rear camber link out through a hole in the belt cover.
- Been thanked: 289 times
LOL Just noticed that too, guess it makes the belt cover rather pointless, doesn't it?Hotshotman wrote:That's a really nice Kong! I noticed they run the upper rear camber link out through a hole in the belt cover.
I always wanted a Kong as a kid. That was the truck that RCCA showed floating in water, right?
- JK Racing
- Has thanked: 103 times
- Been thanked: 200 times
I think the MRP high roller was the "floater".
- m_vice
- Regular Member
Yes, it seems pointless in the pics.Coelacanth wrote:LOL Just noticed that too, guess it makes the belt cover rather pointless, doesn't it?Hotshotman wrote:That's a really nice Kong! I noticed they run the upper rear camber link out through a hole in the belt cover.
My Zerda has a similar arrangement. In that elongated hole in the plastic cover, there is a corrugated shaped rubber boot that snaps in place. On the other end, the boot tapers down and fits tight on the camber link.
I have my purchased new Zerda and noticed that is the one rubber part that deteriorated over the years. Probably why it is missing?
Great looking Kong BTW!
- Has thanked: 2287 times
- Been thanked: 1994 times
I your going to run it at all I'd recommend rehydrating the red nylon parts , I've run my Zerda a fair amount and those red nylon bits get quite fragile , all that's needed is to submerge them in water for 24hours , you can do it quicker with warm water up to 60°C but don't boil them .
Its a nice looking truck you got there and not common at all !
I wonder why they moved the motor ?
- 78 Views
Last post by Dangeruss
- 843 Views
Last post by coxbros1
- 1473 Views
Last post by Lowgear
- 503 Views
Last post by fakiee
- 1448 Views
Last post by DaveM
- 206 Views
Last post by Elkcycles
- 347 Views
Last post by TokyoProf
- 33 Replies
- 4146 Views
Last post by isobarik
